Guest techyguyni Posted August 18, 2014 Share Posted August 18, 2014 (edited) Hi Guys I am in the middle of setting up to servers, both servers running IIS, I understand how to setup network load balancing but something has come to mind that I need explaining!! Firstly I have 2 Network Cards, one for each server, Each network card has or will have a static IP, The problem I face is the following:and maybe a simple explanation will solve this mystery. How do I forward port 80 and 443 on my ISP Router to a Virtual ip the both servers see in the cluster? its virtual and iam assuming the router wont see it as its not given the ip out via its dhcp (dhcp is running on my router not on any of my servers. This has me baffled !!!! Thanks Edited August 18, 2014 by techyguyni Link to post Share on other sites
ikon 439 Posted August 18, 2014 Share Posted August 18, 2014 I assume you mean the NIC is virtual, not the IP. can you ping the IP of the virtual NIC from another PC on the network? If so, then it's visible on the network ---> this is good if the IP address of the virtual NIC is in the same Scope (i.e. the same subnet) as your other PCs on the LAN, then the router should see it just fine. The router does NOT need to have issued the IP in order see it or send packets to it. You don't even have to have DHCP enabled on your router. Link to post Share on other sites
Guest techyguyni Posted August 18, 2014 Share Posted August 18, 2014 Ok I understand that part thank you for your input but how do i port forward in the routers firewall to an ip address that it hasnt issued? thanks again Link to post Share on other sites
ikon 439 Posted August 18, 2014 Share Posted August 18, 2014 You do it the same as you would for any other IP. Every router has a slightly different way to do its Port Forwarding, so I can't give specific instructions, but all you do is enter the Port Forwarding section of your router and then set up an entry as you would any other. In the box where you enter the IP of the destination computer, just enter the IP of the Virtual NIC. Link to post Share on other sites
Guest techyguyni Posted August 18, 2014 Share Posted August 18, 2014 ahhh ok, well ill give that ago, its getting rather late and i need rest.....goto work and work....come home to work !!!!! thanks again Link to post Share on other sites
jmwills 284 Posted August 19, 2014 Share Posted August 19, 2014 The two IP's (one from each sever) will point back to one common IP and that is the address the ports get forwarded to. I assume you don't have a hardware device doing the balancing, right? http://support.microsoft.com/kb/323437 Link to post Share on other sites
Guest techyguyni Posted August 19, 2014 Share Posted August 19, 2014 hi, no I don't have a hardware load balancer, didn't actually know you could get one until recently, load balancing is new to me. would it be a better idea to implement a hardware load balancer? also and a little of the current topic can anyone recommend a ups that have a web interface, I would like to monitor a ups on my network this way? I haven't got one yet but iam on the market for one!!! many thanks Link to post Share on other sites
jmwills 284 Posted August 19, 2014 Share Posted August 19, 2014 Doubt you can afford a hardware NLB. You can do it all through Windows. Link to post Share on other sites
PunkMastaShef 0 Posted December 8, 2017 Share Posted December 8, 2017 Are you using a Unicast or a Multicast? Link to post Share on other sites
