diehard 42 Posted August 9, 2014 Share Posted August 9, 2014 From what I recall, the install checks the OS and will not install if it's the wrong one. Link to post Share on other sites
ikon 439 Posted August 9, 2014 Share Posted August 9, 2014 From what I recall, the install checks the OS and will not install if it's the wrong one. Yeah, exactly what I was thinking. Link to post Share on other sites
infotime 1 Posted August 9, 2014 Author Share Posted August 9, 2014 ccracer tipped me off with the answer over at the wegotserved forums. Turns out that there's a Windows Update that fixes my exact problem. http://support.microsoft.com/kb/2934953 "After you apply update 2960358 for the Microsoft .NET Framework on a computer that connects to a server that is running Windows Home Server 2011, Windows Small Business Server 2011 Essentials, or Windows Storage Server 2008 R2 Essentials with a Unified Extensible Firmware Interface (UEFI) hotfix, all the scheduled client backups fail." Installed the Windows Update. As soon as the server rebooted it began backing up my test PC. I was blindly focused on the question: why didn't this hotfix work. Seems to have worked for everyone else. Maybe I installed it wrong. Maybe my download was corrupt. Maybe I installed the wrong one. Part of me thinks "why didn't I think to check for more updates AFTER the hotfix". And the other part of me thinks "who would ever think that a Windows Update would be required to fix a hotfix". It's too bad Microsoft doesn't mention this in the KB for the hotfix. It would have saved me two and a half days worth of angst. 1 Link to post Share on other sites
ikon 439 Posted August 9, 2014 Share Posted August 9, 2014 Part of the issue, a big part I'm thinking, is because 2960358 has nothing to do with the GPT/UEFI hotfix - it's an RC4 .NET fix. The GPT/UEFI hotfix is 2781272. I suspect what happened in my case is that I had not installed 2960358 at the time I installed 2781272, so the backups were OK right after the hotfix. Link to post Share on other sites
Joe_Miner 254 Posted August 9, 2014 Share Posted August 9, 2014 ccracer tipped me off with the answer over at the wegotserved forums. Turns out that there's a Windows Update that fixes my exact problem. http://support.microsoft.com/kb/2934953 "After you apply update 2960358 for the Microsoft .NET Framework on a computer that connects to a server that is running Windows Home Server 2011, Windows Small Business Server 2011 Essentials, or Windows Storage Server 2008 R2 Essentials with a Unified Extensible Firmware Interface (UEFI) hotfix, all the scheduled client backups fail." Installed the Windows Update. As soon as the server rebooted it began backing up my test PC. I was blindly focused on the question: why didn't this hotfix work. Seems to have worked for everyone else. Maybe I installed it wrong. Maybe my download was corrupt. Maybe I installed the wrong one. Part of me thinks "why didn't I think to check for more updates AFTER the hotfix". And the other part of me thinks "who would ever think that a Windows Update would be required to fix a hotfix". It's too bad Microsoft doesn't mention this in the KB for the hotfix. It would have saved me two and a half days worth of angst. Thanks for posting the Fix to the Fix you found. +1 Link to post Share on other sites
infotime 1 Posted August 9, 2014 Author Share Posted August 9, 2014 Part of the issue, a big part I'm thinking, is because 2960358 has nothing to do with the GPT/UEFI hotfix - it's an RC4 .NET fix. The GPT/UEFI hotfix is 2781272. I suspect what happened in my case is that I had not installed 2960358 at the time I installed 2781272, so the backups were OK right after the hotfix. I'd say that for whatever reason your system wasn't effected by the same issue as mine. I ran all the Windows Updates I could find prior to installing the 2781272 hotfix (well I did the second time I installed it, after uninstalling the failed first go round). 2960358 didn't show up on Windows Update until after I installed 2781272. Link to post Share on other sites
