Western Digital Red/Seagate Barracuda and high fan speed?
Royco
Hello everybody.
I'm new to the forum and this is my first post.
I was wondering about the western digital red/Seagate Barracuda and "fan compatibility".
I've installed three drives in my Microserver Gen 8:
Raid 0 - Seagate barracuda 2TB (salvaged from different system) with OS
Raid 1- Two Western Digital Reds 2TB
I installed Ubuntu 14.04 and included the HPVSA linux drivers (and blacklisted AHCI). The drives are correctly recognized as 2 HP logical volumes and lsmod lists the HPVSA driver.
When I access ILO and look at the HD temperature probe, the temperature is always 50 degrees Celsius (even after a cold boot). This seems rather high and suspect I get an incorrect reading. My fan spins around 20-30%.
Can someone tell me whether the WD Red's give a good temperature reading and can give the low 6% fan speed? I'm considering pulling the Seagate drive and hoping to get a good temp reading from the WD. (Using dd now to clone my drive, will know more in 10 hours).
I updated the ILO firmware to 1.51 and the BIOS is also recent (somewhere middle 2014, 06/06/2014?).
Edited by Royco
I was forced to re-install Ubuntu and now I get a nice HD max reading of 35 degrees Celsius. However, the fan still spins between 20-30%.
If there's a member with 6% fan speed, could they perhaps share their ILO temperature measurements? Maybe I've another hot component and this would help me identify it.
To get 6% the server needs to be set in the cooling mode in the bios that's the top option.  You probably will find you are set in another.
I have an ambient of about 28C today my box is sitting at a low 7% and when I'm down to the usual 18 - 22c it drops to 6% and even sometimes when it goes below 12c here the fan stops and goes to 0% for periods of 20 - 30 minutes.
Those are impressive numbers.
Do you mean the HP power profile setting in the BIOS? Balanced power and performance would be the top option.
I also had a discussion at the HP forum (see here) and found my issue was not Ubuntu specific. Could my PCI graphics be the problem (Sapphire HD5450)? There is a topic at HP about the fan and PCI (see HP ML350e Gen8 Fan Noise). They remove a PCI card and the system becomes quiet.
I'm sure people use non-HP parts in the PCI slot and they should have similar problems, unless it is indeed caused by the hot graphics card and not related to a failsafe mechanism. Do you've an expansion card perhaps?
You didn't mention an add-in GPU previously. That could be rather critical to temperature control.
When I googled "noisy fan", most hits were related to the B120i controller and HDDs. I got distracted. :rolleyes:
For those who might be interested, I pulled the PCI card and now I get the 6% fanspeed under Ubuntu 14.04 with HPVSA.
Here I post a temperature screengrab.
TOP: With card (19% fan).
Bottom: No card (6% fan).
Update:
I put back in the card: started with a 10% fanspeed, which slowly crept up to 19%. That seems hopeful.
Edited by Royco
