EnGenius ESR900 Dual Band 2.4/5 GHz Wireless N900 Cloud Gigabit Router with USB Port and EnShare $30
schoondoggy
I almost got one but reviews not real good. Internal antenna seems to be lacking. Sounds like router has good features though.
I have used several models of EnGenius wireless routers, with quite mixed results. I stopped buying them and switched to Ubiquity.
I have had great luck with the EAP600 WAP. It is a very similar design to the ESR900. The EAP600 is directional, top floor of my house, mounted on the ceiling pointing down, I get coverage over the whole house including the basement. While testing it prior to mounting I had it running on a table upstairs facing up, coverage was good on the second floor, OK on the first and bad in the basement.
