Prototype for stacking drives on SDM for HP MicroServer G8
schoondoggy
I think I final have worked out getting four drives to fit on the SDM. Currently, I have two 7MM SSD's stacked on the back location and two 9.5MM drives on the front. Unfortunately, I can not get two 9.5MM drives to fit in the back location:
It all fits in the HP MS G8:
I had to use 28GA sheet metal and very thin wafer head screws to get it to fit:
I have these out for quote now:
  • 1 month later...
Unfortunately, it has been difficult to take this to production. Sheet metal parts would be very affordable, but I would have to order thousands and there is a setup fee for stamped parts.
I am researching 3D printers, but I am concerned about the strength of the filament they use.
  • 3 weeks later...
Any luck?
Is this a flat bracket that needs no forming (aka no bends, just flat)?
Edited by NateN34
Any luck?
Yes, flat with 4 holes, but it needs to be very thin.
Thin and small also means, shops want/need to make tooling to stamp them out. Tooling cost $$$$ and minimum orders of 2500-5000 pieces.
