ImTheTypeOfGuy 55 Posted June 23, 2014 Share Posted June 23, 2014 My S2008R2 quit working about 8.5 months ago and I am just now getting to troubleshooting. You can see the specs in my signature. When I turn it on nothing appears on the screen. The drives do spin up. I reseated every cord and am thinking it is a GPU issue given the screen is black and doesn't show the post process. Any other thoughts? Link to post Share on other sites
Poppapete 104 Posted June 23, 2014 Share Posted June 23, 2014 Any Beeps? EVGAX58 should have on board speaker with beeps. Link to post Share on other sites
schoondoggy 900 Posted June 23, 2014 Share Posted June 23, 2014 I would try the monitor on another system to be sure it works. If it does, I would swap out the video card. Link to post Share on other sites
jmwills 284 Posted June 23, 2014 Share Posted June 23, 2014 If you are not hearing or seeing a POST sequence, then I would try another video card as suggested and also look at the CPU to see if if has become unseated. Link to post Share on other sites
ImTheTypeOfGuy 55 Posted June 23, 2014 Author Share Posted June 23, 2014 There are no beeps. I have tried two different monitors. Since there are no beeps, could that be the motherboard? Could the GPU keep it from beeping? Link to post Share on other sites
jmwills 284 Posted June 23, 2014 Share Posted June 23, 2014 Are you using the onboard graphics card? If so, you need to test with an add-on card. Have you tried a second cable too? Link to post Share on other sites
Technogod 8 Posted June 23, 2014 Share Posted June 23, 2014 Remove all add-in cards and disconnect all external devices. Are there any beeps when powered on? Do you have a power LED on the motherboard? Still no beeps. Replace power supply or motherboard. Link to post Share on other sites
schoondoggy 900 Posted June 23, 2014 Share Posted June 23, 2014 There is a two digit LED on the motherboard that shows post codes. Pull the cover off and see what show on the LED. Codes are listed in Table 6: http://www.evga.com/support/manuals/files/132-bl-e758.pdf Link to post Share on other sites
ImTheTypeOfGuy 55 Posted June 24, 2014 Author Share Posted June 24, 2014 This MB doesn't have an integrated GPU. So it is an add-on EVGA GeForce GT 240 GPU. When first powering on the computer all fans start and the OS HDD's do spin up. The codes at first alternate between F3 and F6. After about 10 seconds the sequence of 02 EA 01 b8 repeats until I power down. I removed all cards, except the GPU, and all hard drives and came up with the same code. I then removed the GPU and again the same code. I then removed four of the six sticks of memory, same code. I then removed one of the two remaining sticks and received a different code but I can't find what I wrote down now. Looking at the manual I don't see F3, F6, EA, or b8 listed as a code. Unfortunately I don't have a spare GPU or PSU so if I need to test one of those I will have to purchase. At no point during this testing did I ever hear beeps or see anything on the monitor. Any other thoughts? Thanks for all the support so far. Link to post Share on other sites
schoondoggy 900 Posted June 24, 2014 Share Posted June 24, 2014 This points to an issue with the motherboard: http://www.tomshardware.com/forum/304862-31-signal-monitor Link to post Share on other sites
