B120i vs Storage Spaces
sebus05
Guest Dopke139
On ‎22‎/‎05‎/‎2014 at 12:32 PM, psikey said:
If you use the B120i RAID the hard drives will not go into standby but the fan controller works perfectly keeping the case fan at low speed(and noise).
If using 4 x SATA drives with Storage Spaces the drives can power down but the built-in iLO4 fan control doesn't detect the hard drives temperatures so defaults to a higher fan speed that some find too noisy.
Performance wise I'd think not much in it.
Best solution for me was to use 4 individual SATA configured drive using Stablebit DriveSpace for pooling/data duplication.
What if you still use the B120i to present your individual disks as RAID 0 volumes then group these together for parity using storage spaces? Would this get around the fan speed issue or am I overlooking something obviously wrong with this idea?
