new installation of r2 with lots of errors need help
JW, doesn't it sounds like he wants Roaming Profiles? Not that I'm a big fan per se, but doesn't it sound like it?
  • Replies 136
  • franky402
    63
  • jmwills
    51
    17
  • jem101
    6
Popular Posts
Friends don't let friends use UPnP Just in general, don't use it.
jmwills
Setup didn't ask me anything about ad or dns settings. When would I configure this
  You don't.  It's already there.
Check the DNS setting on the server NIC, it should be 127.0.0.1
franky402
I was looking into that but read there can be issues between 8 and 7. I just need four users to have access to QuickBooks
jmwills
Sounds to me like he wants to install Quickbooks on the server and run the application from the client.
jmwills
Wow you are correct lol.. now should iadd my static ip and default subnet
  Yes and reboot.  Create a reservation on the router too.
You should be looking at:
192.168.1.2
255.255.255.0
192.168.1.1
127.0.0.1
No Entry
Now the clients will look to 192.168.1.2 for DNS.  Just make sure it is not running on the router
franky402
192.168.1.2
255.255.255.0
192.168.1.1
127.0.0.1
No Entry
Ok what about my two errors already
franky402
If it's just QB, I believe they have a server-based version.
You install to the server to manage the central database then you install on clients to sync..I want to run the program from the server so no matter the device they can use it
And I dont see anything in the router about dns just dhcp
Edited by franky402
jmwills
What two errors?  You will NEVER have a server that doesn't have errors, or what it thinks to be errors.
What are the codes?  What research have you done on this?  Don't install any third party program or connect clients until the server is stable.
