new installation of r2 with lots of errors need help
franky402
I've been battling with this for a while now. Everything seems to work for the most part but many errors are popping up in the logs. Alot of permission denied errors..Windows time is falling as time server, dns errors and some other crap about adds..I'm pulling my hair out since I'm fairly new to server products. I have resourced some ebooks about server 2012 but don't really tell you much about detailed troubleshooting. I figured you guys here know much more than me. I gotta get this thing running smoothly by the am. I'll post up detailed logs of the errors here in a few moments. Any ideas?
  • Replies 136
  • jmwills
    51
    17
  • jem101
    6
  • franky402
    63
Ok....so after reading through the logs i decided most of the issues had to be dns so i deleted everything dns rebooted set up dns server again restart configure restart and nearly every issue fixed itself..  ill keep an eye on it to see what else is popping up.  Gotta look around now for some easy remote server management stuff as the server box is going to be headless..
Glad to hear you seem to have found the issue.
For remote management why not use Remote Web Access?
well i wish i had.  seems im having way too many issues. I installed the role for remote app and now im having tons of dns errors again.  idk what the hell is going on here
getting these now
4013 The DNS server is waiting for Active Directory Domain Services (AD DS) to signal that the initial synchronization of the directory has been completed
1202 The DFS Replication service failed to contact domain controller  to access configuration information
1202 This computer is now hosting the specified directory instance, but Active Directory Web Services could not service it.
Edited by franky402
Is this the only DC on the domain?
Yes it is, it will be serving about 4-8 clients, atm no clients are connected im wanting to sort out all issues first and its kicking my butt
Edited by franky402
DNS is coming from the router or the server?
Thats what i may be confused on.  lan is static 192.168.1.2 sub 255.255.255.0 gateway is router address. dns is set to look to 192.168.1.2 for server..right? I got upset and did delete all the forward and reverse zone in dns manager and did create dns server through wizard with forward zones
and upnp is activated on the router as well if that matters
Edited by franky402
Yeah, UPnP does matter.... turn it off! It's a huge security risk.
JW, doesn't DNS need to be set to 127.0.0.1?
i thought about loopback but most of the articles i read were using server ip.  and upnp was for setup but i can be turned off now it doesnt need it anymore? and will that cause these issues or just general turn it off
