BigPike 1 Posted May 6, 2014 Author Share Posted May 6, 2014 Esxi hangs even if I use individual sticks. But it takes longer time. Didt wait 5 min before. But the stock memory, the 4 GB works very much fine. Link to post Share on other sites
ikon 439 Posted May 6, 2014 Share Posted May 6, 2014 Then this really sounds like a HW/SW compatibility issue. It could be that ESXi may not be able to install using any 8GB sticks in a MicroServer. But, how about a workaround: what about installing ESXi using the 4GB stick, then swapping it out for 1 or both 8GB sticks after installation is complete? You might even be able to have all 3 sticks installed after installation. Link to post Share on other sites
BigPike 1 Posted May 6, 2014 Author Share Posted May 6, 2014 It works sometimes, sometimes not. No logic at all! But ESXi hangs even if I install it with a 4gb and replace it afterwards with 8 gb. But sometimes it works and then it works very good. Very stable. It hangs under the installation on different places everytime, on the loading screen No logic! Link to post Share on other sites
ikon 439 Posted May 7, 2014 Share Posted May 7, 2014 But it always works with 4GB sticks? If so, that may be the route you have to take. Link to post Share on other sites
BigPike 1 Posted May 7, 2014 Author Share Posted May 7, 2014 I am able to ping it, for a while. Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=3ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Reply from 192.168.1.8: bytes=32 time=1ms TTL=64Request timed out.Reply from 192.168.1.2: Destination host unreachable.Reply from 192.168.1.2: Destination host unreachable.Reply from 192.168.1.2: Destination host unreachable.Reply from 192.168.1.2: Destination host unreachable.Reply from 192.168.1.2: Destination host unreachable.Reply from 192.168.1.2: Destination host unreachable. But it always works with 4GB sticks? If so, that may be the route you have to take. I cant have only 4GB in the server. Link to post Share on other sites
BigPike 1 Posted May 7, 2014 Author Share Posted May 7, 2014 I just started the installation och Server 2012 R2. It hang while I typed the key! Link to post Share on other sites
ikon 439 Posted May 7, 2014 Share Posted May 7, 2014 I cant have only 4GB in the server. Actually, I was thinking of filling all slots with 4GB sticks. Link to post Share on other sites
mdss 6 Posted May 7, 2014 Share Posted May 7, 2014 Have you installed 2012 R2? By the screen shot on the other page, your memory appears to be KVR16E11/8. Not sure if there's any difference between the KVR and system specific models like KTD, KTH, KTL. Link to post Share on other sites
BigPike 1 Posted May 7, 2014 Author Share Posted May 7, 2014 (edited) Hmm, how can you tell its KVR16E11 and not KTD-PE316E/? And no, I didt manage to install 2012r2 because of its freezes. Edited May 7, 2014 by BigPike Link to post Share on other sites
mdss 6 Posted May 7, 2014 Share Posted May 7, 2014 I can't tell for sure, and I'm not sure what the differences are between the regular KVR and the system specific models for major OEMs, but looking up the code from your screenshot I found a PDF on the Kingston's website where the same BOM number is listed for the KVR16E11 module. I just tested another T20 with 4x 4GB Hynix UDIMMs and everything is stable. The modules are the original T20 Hynix (taken form 3 other machines). I also tested with a 4x 8GB 1333MHz 1.5V kit and there are no signs of stability problems. I still recommend low volt 1.35V memory for Haswell machines that run 24x7. Link to post Share on other sites
