DonaldR 0 Posted April 27, 2014 Share Posted April 27, 2014 (edited) I was setting up my back up schedules and all was going fine so I thought. Seems WHS2011 pauses/stops the back up when it moves to the raid 0 drives. The set up is two 2tb drives set up in raid 0 with a High Point Rocket Raid 2720 SGL raid controller. In the process of elimination I found that all the non-raid drives, C through E backed up with 100% success. I then re-configured auto back up for only the Raid 0 drives, and started a manual back up. WHS 2011's Dashboard shows that it is preparing the backup (you can see the heavy HD activity via the drive LED). It then changes the message to "backing up" and there is no progress. No HD activity, no percentage of progress. If this is an incompatibilty with the Rocket Raid controller and WHS 2011 then I'd like to know for sure as I can eliminate my raid and run it as two separate drives. The O/S is installed on it's own drive which is connected to the motherboard and completely independent of the raid. The hardware is a Intel i5 CPU attached to a Gigabyte GA-Z77-D3SH revision 1.1 and 8 gB of Patriot memory. The backup drive is an external 3TB Seagate Contellation inside a enclosure connected via USB 3.0. Thanks Don Los Angeles Edited April 27, 2014 by DonaldR Link to post Share on other sites
DonaldR 0 Posted April 27, 2014 Author Share Posted April 27, 2014 In addition HighPoint assured me that the Rocket Raid 2720SGL is compatible with the Gigabyte GA-Z77-D3SH motherboard and WHS 2011. Link to post Share on other sites
jmwills 284 Posted April 27, 2014 Share Posted April 27, 2014 Do you have a spare internal bay to mount that and eliminate the USB factor? Link to post Share on other sites
DonaldR 0 Posted April 27, 2014 Author Share Posted April 27, 2014 The back-up is working now. I updated the Rocket Raid drivers and may have fixed it. It's also possible that compared to the much smaller smaller amount of data on the other drives this takes longer for the process to advance. The idea of the external back-up is ot have easy access to the data in the event of a hardware failure within the server, or at least that is how I was taught. Link to post Share on other sites
jmwills 284 Posted April 27, 2014 Share Posted April 27, 2014 I was just trying to eilminate a third party tool, not saying it is a bad practice to have the backups externalized. Link to post Share on other sites
DonaldR 0 Posted April 28, 2014 Author Share Posted April 28, 2014 (edited) I was just trying to eilminate a third party tool, not saying it is a bad practice to have the backups externalized. The USB 3.0 drivers are included with the motherboard. Now that I actually sat down and read the section about back-ups in WHS2011 Unleashed Third Edition by Paul McFedries, I understand that I have been a bit impatient. Once WHS2011 scans and checks for portions of the back-up which may need to be appended and either writes or skips over, the back-up moves quite quickly and finishes in a short amount of time. I'm glad I opted for a enterprise quality 3TB drive for the external backup as WHS2011 keeps it quite busy while scanning through the existing files while looking for any changes or additions which are to be made. Edited April 28, 2014 by DonaldR Link to post Share on other sites
ikon 439 Posted April 28, 2014 Share Posted April 28, 2014 LOL, you answered what would have been my 1st question: exactly how long did you wait to see if there was any progress? Link to post Share on other sites
