$238.99 N54L MicroServer & N150 Wireless Router with Code EMCPGHC228 & MIR
Joe_Miner
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • chickenlip007
      By chickenlip007
      Hi Guys, have a strange issue whereby my N54L won't turn off, it just reboots. The same behavior is seen when using Windows or Vmware, when shutting down, the server proceeds to start the shutdown process but powers itself up again immediately. I have tried resetting the Bios, removed the board and all components, re-installed and still the same.
      I moved the mainboard into a spare Microserver Chassis with the same result (to rule out any cabling issues). I have changed the RAM modules as well, with no luck.
      It is worth mentioning that the onboard NIC no longer works either, I have replaced with a PCIex card that works fine. Holding down the power button for 5 seconds will turn off the server but immedately starts back up when it is released. I have compared BIOS settings to another working Microserver in my LAB, same results.
      I am honestly out of ideas, spent way too many hours scratching my head over this one. the only way to get it to stay off is wait till the splash screen loads then pull the power plug, which is not ideal.
      Anyone else have any ideas?
      thank you!
    • E3000
      By E3000
      Hey guys,
