ikon 439 Posted March 19, 2014 Share Posted March 19, 2014 I think 25/10 is faster than most people have. I do have 25 down, but only 2 up, and I have one of the fastest options available from my ISP. From what I've seen, speeds around the world vary considerably. Link to post Share on other sites
oj88 136 Posted March 20, 2014 Share Posted March 20, 2014 Sorry for being kinda my fault for setting up the path to go off topic. Anyway, my recommendation for setting up a DD-WRT router is to check the router hardware itself. Having more flash and RAM as well as a beefier CPU, will give you more flexibility and can most likely help make it more stable on high-BW and multiple simultaneous sessions. Alternatively, you can also consider loading it up with Tomato. DD-WRT is more feature-rich of the two, which can also be a potential to make it a bit less stable. Tomato on the other hand, is sort of the middle-ground between the stock firmware and DD-WRT.... just enough of the bells and whistles for most folks. Personally, I'm biased towards pfSense running on a small Atom box... coz that's what I settled on. Link to post Share on other sites
Don W 4 Posted March 20, 2014 Author Share Posted March 20, 2014 I think I have decided on the Atom PC route, how does this setup look? 1. OEM Production 2550L2D-MxPC Intel NM10 2 x 204Pin Intel GMA 3650 2. How much RAM should I get? 3. Small SSD??? http://www.newegg.com/Product/Product.aspx?Item=N82E16856205007 Link to post Share on other sites
