Foscam Pan/Tilt Wireless IP Camera w/ 26' Infrared Night Vision, Smartphone Remote Viewing & Motion Detection! $89.99
schoondoggy
Anyone know whether it's possible to either 1.) enable auto night vision detection for an IP Camera in Blueiris or 2.) schedule in Blueiris when the camera's night vision IR lights should be enabled?
I have an "older" model Foscam, and use Blue Iris. It definitely automatically enabled IR/night vision just fine. And can be used to toggle it manually. But works great on "automatic". Just hold down the IR button till it shows the on/off state side by side on the button.
Thanks Drashna. I think it resets this each time BI restarts. Also not sure it sticks when you run BI as a service. I may need to set BI to start with Windows and stay logged into the server.
You can schedule this to happen in BI either globally or for an individual camera.
Poppapete - where in BI? Am searching for this setting. Currently I have the schedule defined at the camera level instead of global. But didn't notice an IR light setting within scheduler.
Sorry! I led you up the garden path. I use Milestone and Blue Iris and the Hikvision app. It appears IR CANNOT be controlled from BI. :unsure:
From what I see with my BlueIris setup, it stays in the state between reboots.
I do run it as a system service. so it runs without having to log in.
But this does depend on the camera.
yeah, my TPLink cameras are like that as well. They won't let BlueIris properly auto-configure the IR/night vision, but the cameras do it on their own fine.
Drashna,
Are there any disadvantages with running BI as a service? It appears this is the best way to get it to run at boot !
Running as a service is the way to go.
Am in the market for another camera. Would like day/night vision and at least 720P res. POE would be nice but not required. Currently using Foscam FI9821W. Was hoping for something better.
