mSD Card, why?
Trig0r
I believe it's intended to be used as the boot drive for some OS': e.g. ESXi.
This is correct. You can Run Hyper-V this way too in a core installation.
  • 1 month later...
For reference.
I did find this mSD slot convenient for a lab box.
I loaded VMWare on it, and leave my HDD to Hyper-V 2012 server.
May choose which server I'd like to boot from the boot menu this way.
So... not suggested to use the mSD to boot Ubuntu Server 12.04?
While I'll acknowledge not being a Linux guru, it might be okay, if you ensure your swap partition is in another location.
As others have said, the key is an OS that doesn't do a lot of writes to the SD card.  ESXi is good for this, XenServer is probably good too.
If you only want to *boot*, you could put grub or another boot loader on the sd and the OS install on a real disk.
If you are talking about installing the OS itself to the SD card, I wouldn't bother unless it was a real basic text mode only distro.
i think the reason for its implementation is to allow a hypervisor to boot as they load themselves into memory and run from there, rather than a traditional OS which uses the disk for operation.
