ttt Posted July 8, 2020 Share Posted July 8, 2020 For anyone else who ends up here like I did due to the noise the standard fan makes, there is a compatible plug on aliexpress if you search for "Connector for HP Microserver Gen8 Fan Shield Plug". I used it to fake the fan signal and replace the fan with a normal 3 pin via molex adapter. The wires it came with were in the wrong 3 slots with reference to the plug's orientation but they are easily popped out and relocated. 1 Link to comment Share on other sites More sharing options...
dosser Posted July 8, 2020 Share Posted July 8, 2020 Can't find the connector on aliexpress. Have you a link for this. Link to comment Share on other sites More sharing options...
beyeriii Posted October 24, 2021 Share Posted October 24, 2021 Search Google for "Fan Shield Plug", e.g. Connector for HP Microserver Gen8 Fan Shield Plug https://www.aliexpress.com/item/4000360209436.html 1 Link to comment Share on other sites More sharing options...
