Dropping RDP Connection
gyrene2083
Hello All,
I know it's been a while, but I was moving along ok with Essentials, until about two months or so ago. I RDP from my Win 8.0 laptop to Essentials, and what's been happening is that after 45 or 50 seconds or so I could see the connection still on my laptop but I can't do anything on the server, then a disconnect screen comes up, then it auto reconnects. This, for me, is a huge pain in the ass considering I am using my server for my Media. I would appreciate any help I can get.
  • Replies 20
  • Drashna Jaelre
    2
  • jmwills
    4
    4
  • gyrene2083
    9
It could be packet loss between your laptop and the server.  You could try running a ping -t <ip of your server> and watch and see if there is any loss.
It was working fine for quite sometime, but I tried what you said as I'm at my whits end, and here is what I have:
Ping statistics for 192.168.1.x
      Packets: Sent = 66, Received = 66, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
      Minimum = 1ms, Maximum = 2ms, Average = 1ms
Could it be anything else?
Seriously? Man that would so suck. How could I be sure it's the cable? and if it is would that also explain why I am getting dropped frames in xbmc?
A new cable is a relatively cheap & easy way to test. It's possible that you, or someone else, accidentally kinked the existing cable and it's not working reliablly any more.
Before actually swapping out the cable, try simply unplugging the RJ45 connector and reinserting several times at both ends of the cable, just to refresh the connections.
Your all right the cables are fairly cheap but I was the one who made the cable and ran it through concrete walls, and would really hate to have to go through ripping out that one cable to redo it all over again, I suppose that was why I was so unhappy to think it was the cable.
I suppose I could take the server out of the closet then bring it out to the living room and plug it into the switch. <bangs head against keyboard> But this is how we learn right?
Thanks guys for all the input I'll tackle this reluctantly maybe this weekend and keep you all posted.
run "netsh interface tcp set global autotuning=highlyrestricted" from an elevated command prompt. See if that helps.
If it doesn't, run "netsh interface tcp set global autotuning=disabled"
