Linksys WVC80N Wireless-N Internet Home Monitoring Camera - $57.99
schoondoggy
I've been wanting to get a couple, mind sharing what you recommend?
Sent from my HTC One using Tapatalk
I have a couple of TRENDnet TV-IP551WI Day/Night IP cameras that are pretty great.
The IR isn't as configurable as I'd like, but works very well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16881102060
I have a Foscam  FI8918W cam too (but some of these have a firmware bug that crashes the camera, if the image is very white, IIRC)
The IR isn't great quality on the model I have, but it does work well.
http://www.newegg.com/Product/Product.aspx?Item=9SIA1R20TH9404
But I would recommend against any of the Linksys WVC cameras. I have 4-5 of these. And when I have 3 or more attached to the network (over wired), it would crash my Linksys router's Wireless AP. This was on stock firmware, and DD-WRT. And with the router acting as just a router, or as an access point,
That's why I can't recommend these. And I got them free from a friend that was more than likely having the same issue as me.
What I want to use the camera for is in an industrial environment to monitor a process while getting it set up. The camera won't be permanent, only while the process is being tested, so I don't need a true industrial camera. Possibly a usage out of character for most users here, but any suggestions?
