AVsonyfan Posted February 27, 2014 Share Posted February 27, 2014 Well I thought I would share my latest non-success and hopefully gain some insights on what I can do next.... I took apart my N40L last night as I had a cunning plan of putting an HP Ultrium 920 SAS LTO3 drive in the top and connecting it via an HP SC44ge SAS card I just happened to have loitering in a drawer with its cable. Yes a strong case for too much tech! All went well and card seemed correct height until after removing the mobo I realised that the mounting bracket was too high to fit the chassis backplane. Drat and double drat! I was wondering if the rear mounting panel could be removed as won't need the external SAS port (or will I) but before I headed to find a different bracket or took a hacksaw to the current one I returned it all back together and put the kettle on! Any suggestions? Link to comment Share on other sites More sharing options...
schoondoggy Posted February 27, 2014 Share Posted February 27, 2014 Check to see how far apart the screw holes in the board are,,, hopefully 54mm: http://www.ebay.com/sch/i.html?_sacat=0&_from=R40&_nkw=lsi+low+profile+bracket&_sop=15 Drill a pilot hole and nibble out the rest of the hole with one of these: http://www.amazon.com/Parts-Express-Nickel-Plated-Nibbling/dp/B0002KRACO/ref=sr_1_2?ie=UTF8&qid=1393529449&sr=8-2&keywords=metal+nibbler Link to comment Share on other sites More sharing options...
AVsonyfan Posted February 27, 2014 Author Share Posted February 27, 2014 Thanks for the idea and links! Yes they are 54mm spacing Link to comment Share on other sites More sharing options...
