PCI-Express TV Card, will it fit
chrisoldroyd
Thinking of popping a TV Card in my N54L and not sure if the card will fit, anyone tell me for sure?
TBS DVB-S2 High Definition Digital Satellite Tuner PCI Express Card HD (DVB-S2/DVB-S)
http://amazon.co.uk/dp/B002GNLUOY
Specification
Receiving Freq: 950-2150MHz Input level: -69~-23dBm
Supports Data Burst & Tone Burst. Support DiSEqC2.X and Motor
Low profile size: 128x59mm (LxH)
Full specification available from manufacturer's website
System Requirements
Windows 2000/XP/Vista/7/8 or Linux
DirectX 9.0 or later Version
Available PCI Express x1, x4, x8 or x16 slot
Satellite Dish and LNB
For DVB-S: 1GHz CPU or above, 256MB RAM or above, graphics card with16MB RAM or above
For DVB-S2 HDTV: Dual Core CPU, 1GB RAM or above. Graphics card with 64MB RAM or above
Chris
