ChadRT Posted March 5, 2014 Author Share Posted March 5, 2014 From Server: Windows PowerShellCopyright © 2013 Microsoft Corporation. All rights reserved.PS C:\Users\chad> tracert google.comTracing route to google.com [173.194.33.105]over a maximum of 30 hops: 1 40 ms 25 ms 22 ms CPE-76-178-18-129.natmtn.res.rr.com [76.178.18.129] 2 15 ms 9 ms 11 ms ge1-1-4.cralid-rtr1.cralid-rtr1.natnow.rr.com [65.28.217.57] 3 20 ms 17 ms 17 ms ae21.sstswa5802r.natnow.rr.com [65.28.218.248] 4 22 ms 30 ms 18 ms 107.14.19.114 5 38 ms 38 ms 38 ms bu-ether11.sttswa5800w-bcr00.tbone.rr.com [66.109.6.16] 6 40 ms 35 ms 38 ms ae-2.cr0.sjc10.tbone.rr.com [66.109.9.44] 7 35 ms 37 ms 37 ms ae-0-0.pr0.sjc10.tbone.rr.com [66.109.6.141] 8 54 ms 57 ms 55 ms 74.125.48.253 9 37 ms 36 ms 37 ms 209.85.249.310 37 ms 36 ms 36 ms 209.85.246.25311 40 ms 38 ms 36 ms 216.239.49.19812 39 ms 36 ms 40 ms 209.85.248.22113 35 ms 37 ms 36 ms 66.249.94.19614 36 ms 36 ms 36 ms 209.85.244.6315 37 ms 36 ms 36 ms sea09s16-in-f9.1e100.net [173.194.33.105]Trace complete. When I do tracert "servername" or tracert "servername.local" it shows the single hop to the server. From Workstation: Unable to resolve target system name google.com. Link to comment Share on other sites More sharing options...
jmwills Posted March 5, 2014 Share Posted March 5, 2014 That first hop should be your local DHCP server and it looks like that is your external address so yes, none of the clients are getting an IP. C:\>tracert google.comTracing route to google.com [74.125.21.138]over a maximum of 30 hops: 1 3 ms 5 ms 4 ms router.asus.com [192.168.1.1] 2 29 ms 17 ms 21 ms 96.120.19.13 3 39 ms 14 ms 15 ms te-9-3-ur02.huntsville.al.hunts.comcast.net [68.85.33.97] 4 16 ms 21 ms 16 ms xe-0-0-8-0-ar04.huntsville.al.hunts.comcast.net[68.85.227.5] 5 23 ms 27 ms 25 ms xe-19-1-3-0-ar01.b0atlanta.ga.atlanta.comcast.net [162.151.13.34] 6 23 ms 20 ms 20 ms he-5-15-0-0-10-cr01.56marietta.ga.ibone.comcast.net [68.86.87.201] 7 48 ms 35 ms * as15169-1-c.56marietta.ga.ibone.comcast.net [23.30.206.146] 8 21 ms 23 ms 22 ms 72.14.233.54 9 24 ms 29 ms 30 ms 66.249.94.6 10 44 ms 44 ms 19 ms 64.233.175.12 11 * * * Request timed out. 12 31 ms 24 ms 24 ms yv-in-f138.1e100.net [74.125.21.138] Link to comment Share on other sites More sharing options...
ChadRT Posted March 5, 2014 Author Share Posted March 5, 2014 I found this! And if the DNS server cannot start then "Houston we have a problem..." could this be causing the mess I have now? Event Type: WarningEvent Source: DNSEvent Category: NoneEvent ID: 4013Date: 3/4/2014Time: 2:28:37 PMUser: N/AComputer: xxxx.xxxx.localDescription:The DNS server is waiting for Active Directory Domain Services (AD DS) to signal that the initial synchronization of the directory has been completed. The DNS server service cannot start until the initial synchronization is complete because critical DNS data might not yet be replicated onto this domain controller. If events in the AD DS event log indicate that there is a problem with DNS name resolution, consider adding the IP address of another DNS server for this domain to the DNS server list in the Internet Protocol properties of this computer. This event will be logged every two minutes until AD DS has signaled that the initial synchronization has successfully completed. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. And this one! Holy cow so if the DNS server cannot start or bind to 192.168.1.1 which is the default gateway for the clients then it would cause them not to have internet? Event Type: ErrorEvent Source: DNSEvent Category: NoneEvent ID: 408Date: 3/2/2014Time: 3:32:44 PMUser: N/AComputer: xxxx.xxxx.localDescription:The DNS server could not open socket for address 192.168.1.1.Verify that this is a valid IP address for the server computer. If it is NOT valid use the Interfaces dialog under Server Properties in the DNS Manager to remove it from the list of IP interfaces. Then stop and restart the DNS server. (If this was the only IP interface on this machine and the DNS server may not have started as a result of this error. In that case remove the DNS\Parameters\ ListenAddress value in the services section of the registry and restart.)If this is a valid IP address for this machine, make sure that no other application (e.g. another DNS server) is running that would attempt to use the DNS port.For more information, see "DNS server log reference" in the online Help. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. Link to comment Share on other sites More sharing options...
jmwills Posted March 5, 2014 Share Posted March 5, 2014 No. It would not allow DNS resolution. Accessing the internet is about making connections. DNS only turns IP addresses into friendly names. Link to comment Share on other sites More sharing options...
timekills Posted March 5, 2014 Share Posted March 5, 2014 No. It would not allow DNS resolution. Accessing the internet is about making connections. DNS only turns IP addresses into friendly names. The only part that throws me is his nslookup does show trying to reach 8.8.8.8, but he says he can't even ping 8.8.8.8. Even without DNS resolution he should be able to ping the IP. If it were truly a DNS problem, he should be able to statically assign the DNS in his NIC's settings and resolve URLs. That's why I suggested that earlier to either confirm or rule out a true DNS problem. Clearly he isn't resolving the names to IPs, but the lack of any internet connectivity would make me look elsewhere. Of course, the rule of thumb is after layer 1, blame DNS so... Link to comment Share on other sites More sharing options...
jmwills Posted March 5, 2014 Share Posted March 5, 2014 But still, that first hop should be his local DHCP server and it's not. This is why the clients are not pulling an address. There is a configuration issue somewhere either in cabling or RRA. If the server is being used as the DHCP server, once cable should be coming from the router/modem WAN port to the NIC where DHCP is bound. The "WAN NIC" on the server should go back to the LAN port(s) on the router as would any other NIC needing external access. Link to comment Share on other sites More sharing options...
jem101 Posted March 5, 2014 Share Posted March 5, 2014 (edited) We have three possible issues here 1) DHCP is not working correctly on the LAN side 2) DNS is not working correctly on the LAN side 3) Routing internet traffic between the networks on the server is not working properly. Of these 3) is going to be the hardest to fix, so we'll start with checking that out. On one of your client PCs, statically set the following IP address parameters IP address : 192.168.1.99 Subnet mask : 255.255.255.0 Default gateway : 192.168.1.1 Set DNS to be 8.8.8.8 (this doesn't really matter for this test) By the way I am assuming that .99 is not being used for anything else. Then on the client side open a command prompt or powershell and try tracert 8.8.8.8 and see if it gets out to the internet - if not (ie it gives out at the first hop) then we have a RRAS issue and nothing is going to work until we get that working. If it does go out ok, then try tracert www.google.com and see what that returns. If nothing then we have a DNS issue to look into. John Ah I've just read back some of your earlier posts, if the RRAS role is installed on the server then it shouldn't have a default gateway entered on the LAN side - only the WAN side nic should have a gateway address. So the LAN nic should have IP address 192.16.1.1 Subnet 255.255.255.0 Gateway address : leave this blank DNS - well if the server also has the DNS role installed then this should be 127.0.0.1 or 192.168.1.1 (either is OK) Edited March 5, 2014 by jem101 Link to comment Share on other sites More sharing options...
ChadRT Posted March 5, 2014 Author Share Posted March 5, 2014 But still, that first hop should be his local DHCP server and it's not. This is why the clients are not pulling an address. There is a configuration issue somewhere either in cabling or RRA. I would assume that since I was able to move files from computer to computer and access the server from the client workstations that cabling would be ruled out completely? I am able to ping the server, ping other workstation from a workstation, ping workstation from server and the workstations receive an IP from DHCP. On one of your client PCs, statically set the following IP address parameters IP address : 192.168.1.99 Subnet mask : 255.255.255.0 Default gateway : 192.168.1.1 Set DNS to be 8.8.8.8 (this doesn't really matter for this test) By the way I am assuming that .99 is not being used for anything else. Then on the client side open a command prompt or powershell and try tracert 8.8.8.8 and see if it gets out to the internet - if not (ie it gives out at the first hop) then we have a RRAS issue and nothing is going to work until we get that working. If it does go out ok, then try tracert www.google.com and see what that returns. If nothing then we have a DNS issue to look into. So the LAN nic should have IP address 192.16.1.1 Subnet 255.255.255.0 Gateway address : leave this blank DNS - well if the server also has the DNS role installed then this should be 127.0.0.1 or 192.168.1.1 (either is OK) This is all really good stuff were talking about here. Things I have not tried. Link to comment Share on other sites More sharing options...
ChadRT Posted March 5, 2014 Author Share Posted March 5, 2014 John, I followed your steps. One thing I did have was in the LAN adaptor I had statically set the DNS entries to google's but I did have the gateway empty. Now that I have the LAN running 192.168.1.1 as the primary DNS server here are the results. (BOTH OF THE FOLLOWING HAVE STATIC .99 AS PER INSTRUCTIONS ABOVE) Client Computer Configured for Google DNS: ping 192.168.1.1 = good result tracert 8.8.8.8 = first hop thru the server and each consequtive hop is "Request timed out." tracert google.com = Unable to resolve target system name google.com. Client Computer Configured for Server IP as DNS: tracert = all requests time out tracert google.com = Unable to resolve target system name google.com. Link to comment Share on other sites More sharing options...
ChadRT Posted March 5, 2014 Author Share Posted March 5, 2014 But still, that first hop should be his local DHCP server and it's not. This is why the clients are not pulling an address. There is a configuration issue somewhere either in cabling or RRA. If the server is being used as the DHCP server, once cable should be coming from the router/modem WAN port to the NIC where DHCP is bound. The "WAN NIC" on the server should go back to the LAN port(s) on the router as would any other NIC needing external access. I have three NIC's... WAN - Connected to TW cable modem with an assigned static IP from TW (internet works good on server directly) LAN - Connected to a 16 port switch INT - Disabled NIC built into the motherboard Each of the two client computer workstations are connected to the switch, workstations receive a DHCP assignement from the server those workstations are able to file share between themselves, view server intRAnet pages (remote access pages) and also respond to pings from server and eachother. Link to comment Share on other sites More sharing options...
