robertbailey Posted June 5, 2010 Share Posted June 5, 2010 Hi all Looking for some help with this. I know that the current cpu\mb combo is i5 350\Gigabyte set up, but at the moment i just can't afford this, but need the whs back up and running. Cpu null Link to comment Share on other sites More sharing options...
dvn Posted June 5, 2010 Share Posted June 5, 2010 The AMD system sounds decent enough. The Sempron 140 is comparable in processing power to the EX490's Celeron 450. Link to comment Share on other sites More sharing options...
pcdoc Posted June 6, 2010 Share Posted June 6, 2010 For basic server needs it should be fine. Good luck with it. Link to comment Share on other sites More sharing options...
stalni Posted June 10, 2010 Share Posted June 10, 2010 looks good, with the amd system, but why the 785g chipset(sata connections?) I would think a 760g would be cheaper. just a thought, if you have not already ordered. Link to comment Share on other sites More sharing options...
dvn Posted June 10, 2010 Share Posted June 10, 2010 (edited) Yes, I agree. You can save $45 with this board, as long as you can get by with 4 SATA connections. *I went back and noticed that DVI and HDMI are included on this board, as well as VGA. Edited June 11, 2010 by dvn Link to comment Share on other sites More sharing options...
robertbailey Posted June 11, 2010 Author Share Posted June 11, 2010 Thanks for the replies Not ordered anything yet,waiting to see if any deals pop up As for the 785 board i just went for on-board gpu and 6 sata ports Robert Link to comment Share on other sites More sharing options...
