Fan speed
adsboel
Odd, but positive news.
As I mention in another thread, my WD Black array when pearshaped and a disc is faulty. As result bought 2x3TB WD Reds to consolidate my files to and passthru shared this to one of my VM's so it could be shared data within a domain..
While mounting these I experimented abit with where to put the SSD. Tried the ODD cable and some other things... no luck with the SSD, the system got unstable when putting it from Bay 1 to ODD and it seemed like the fans where going as mad they used to (51%) .. I got tired and left all on the floor and when I came home and it suddenly runs at 6-10% ...
scratching my head for reason for this:
- an icybox without hard was not re-inserted, bay 4 was open.
- ab icybox with SSD was remounted with better fit for connectors
- Adding the two WD Reds lowered the average harddisk temp?
- ILO takes time to lower its fan? like average over time ..
It's ofcourse happy news, but anyone else experience this ? going from SSD only in bay one with 50% fan to three bays used (1-3) and 6% and speed. ?
Edited by adsboel
If I read your post correctly, you now have the SSD on the ODD port and 2 WD Reds in the 4-bay cage. If so, I suspect the Reds are responsible for the lower fan speeds, in that they're giving correct sensor readings to the iLO. What do you think?
not correct. I tried SSD on ODD (without changing any bios) and it was unstable when it much to my surprise bootet.
I moved it back so the layout is:
Bay 1 : SSD Corsair Neutron in Icybox
Bay 2 : WD Red 3TB
Bay 3 : WD Red 3 TB
Bay 4 : Empty / open
Controller: built in b120i
After messing around it complained about it couldn't find the SSD in bay one and I refitted them in the icybox and it came alive. However, just after it came alive it was noise as expected around 45% .. after a day at work it was 6%
I also think the WD Reds gave a better 'world view' to the bios .. because there is no 'per disc sensor'.
Anyways, its really happy trouble! I just thought I'd post the finding.
Edited by adsboel
I suspect you're right adsboel: the WD Reds are making the difference.
Have you tried shutting down and rebooting yet, to see if the fan speed stays at 6%: i.e. to find out what the boot from cold start behaviour is?
Some images for anyone researching this problem:
Please note that these temps are after putting the Gen8 back in a closed cupboard with a N36L running additional 5 discs.. abit of heat is in the cupboard.
Edited by adsboel
Hmm, interesting. You got down to 8%, I've got lower temps than you across all sensors but am getting 24%.
I suspect it's due to the P222.
The lowest idle reading I've got was 4% (at nighttime but still inside an urban office, not a meat locker), with Gen8 standing on the top of a credenza & everything in their defaults--RAID mode of course but pretty sure all 5 drives were fired up including a 2.5" 12.5mm disk in the ODD space.
Then a software change resulting in driver incompatibilities caused me to reconfig in BIOS for AHCI which put the idle fan speed in the mid-to-high 30%s.
Incidentally flashing the semi-official November 2013 firmware seems to have pulled that in to around 19%
