Drashna Jaelre 159 Posted February 3, 2014 Share Posted February 3, 2014 I honestly don't know the answer to that question, but I suspect Drashna does. I .... might. This is exactly how I do it. If you setup RDP to use your Anywhere Access address as a Gateway, does this mean that BOTH your RDP credentials as well as the RDP session are completely encrypted using the HTTPS SSL certificate? YES. Specifically, the feature/role you are using is called "Remote Desktop Gateway". It requires an SSL certificate, just like your website does (the same one, in fact). And everything is done over HTTPS. If you've noticed me asking about this when troubleshooting remote access and VPN. This is why. That, and Server 2012 Essentials uses "SSTP VNP", which uses port 443/HTTPS as well. So yes, when using the RDP Gateway, everything, from start to finish is encrypted using your HTTPS/IIS certificate. http://technet.microsoft.com/en-us/library/dd560672(v=WS.10).aspx 1 Link to post Share on other sites
Jason 84 Posted February 3, 2014 Share Posted February 3, 2014 Thanks Drashna for verifying. Good to know. I use Remote Desktop Gateway to RDP into my WSE12 box via my iPad and work laptop. Glad it's fully encrypted. That way I don't have to start a VPN connection and then RDP over it. Saves time. Link to post Share on other sites
Drashna Jaelre 159 Posted February 3, 2014 Share Posted February 3, 2014 And it saves overhead too. And yeah, it's so very nice. And it's used in enterprise deployments like this too. Such a great feature. I also use the RDP Gateway for work. Specifically, I have VM that is always running that is dedicated for my CoveCube related work. I remote into from home, and if I'm away from home. So I depend on it, and am very happy with it. 1 Link to post Share on other sites
Jason 84 Posted April 30, 2014 Share Posted April 30, 2014 And it saves overhead too. And yeah, it's so very nice. And it's used in enterprise deployments like this too. Such a great feature. I also use the RDP Gateway for work. Specifically, I have VM that is always running that is dedicated for my CoveCube related work. I remote into from home, and if I'm away from home. So I depend on it, and am very happy with it. It's been a while, but even when RDP'ing into my network clients via my *.remotewebaccess.com gateway, I don't notice any specific icons that would indicate SSL encryption is active. Is there anywhere you can look to validate this? For example you get a lock icon when HTTPS active and can view certificate info with IE or Firefox, etc. Thanks. Link to post Share on other sites
Drashna Jaelre 159 Posted May 2, 2014 Share Posted May 2, 2014 (edited) No, unfortunately, it doesn't seem to be "documenated" by the client. The best I can find (other than on wikipedia) is this: http://technet.microsoft.com/en-us/library/dd560672(v=ws.10).aspx The end of the first paragraph outlines it though: RD Gateway uses the Remote Desktop Protocol (RDP) over HTTPS to establish a secure, encrypted connection between remote users on the Internet and internal network resources. Edited May 2, 2014 by Drashna (WGS) Link to post Share on other sites
