Alvin Ramard Posted May 31, 2010 Share Posted May 31, 2010 I'm looking for suggestions for software to convert all my audio files to files to MP3 format. At first glance, it looks like M4V, AAC, and WMV, are the main ones I'll be dealing with. I know there's lots of free ones out there but I was just wondering what the group here has to say about them. Thanks in advance. Alvin Link to comment Share on other sites More sharing options...
diehard Posted May 31, 2010 Share Posted May 31, 2010 The MyMovies addin can rip and convert you audio files into 2 formats also. Link to comment Share on other sites More sharing options...
Alvin Ramard Posted May 31, 2010 Author Share Posted May 31, 2010 Thanks, but addins are not an option for me at this time. I'm only running Vail, not WHS1. Alvin Link to comment Share on other sites More sharing options...
pcdoc Posted May 31, 2010 Share Posted May 31, 2010 AlvinYou can try this one. It works with various audio and video formats and what I like about it is batch processing. You can process a bunch of files at once. They have a trial version so you can test drive it first. http://www.pavtube.com/video_converter/ Link to comment Share on other sites More sharing options...
Alvin Ramard Posted May 31, 2010 Author Share Posted May 31, 2010 Thanks pcdoc. I'll check it out. I see they also have a package for copying Blu-Ray movies. I think I need to check that one out too. Alvin Link to comment Share on other sites More sharing options...
pcdoc Posted June 1, 2010 Share Posted June 1, 2010 Had a few issues with their Blu-Ray converter with heavy stuttering but I have never tried their ripper. Let us know how that works out. Link to comment Share on other sites More sharing options...
Alvin Ramard Posted June 1, 2010 Author Share Posted June 1, 2010 pcdoc, I guess I'll have to give it a test run before buying it. Your comment was not too encouraging. It'll be a while yet before I'm ready to try it. I need to get my hand on a Blu-Ray drive first. There goes more money. Alvin Link to comment Share on other sites More sharing options...
pcdoc Posted June 2, 2010 Share Posted June 2, 2010 I am sure that it will not happen to everyone but it did not work for me. One variable though is I was pulling the DB movies from my server not a disk. When I get a chance I will try that. Link to comment Share on other sites More sharing options...
ohpleaseno Posted June 4, 2010 Share Posted June 4, 2010 I use foobar2000 for all audio converting. You wil need to download the encoder for whatever file format you are looking to convert to and from. It will use title-formatting to write file names and directory structures based on metadata. It also can be used as a ripper. Once you get over the learning curve, you will be amazed at what it can do. Link to comment Share on other sites More sharing options...
eobie Posted June 12, 2010 Share Posted June 12, 2010 <p>I'm looking for suggestions for software to convert all my audio files to files to MP3 format. At first glance, it looks like M4V, AAC, and WMV, are the main ones I'll be dealing with.</p><p>I know there's lots of free ones out there but I was just wondering what the group here has to say about them.</p><p>Thanks in advance.</p><p>Alvin</p> Does it need to be done on your WHS? If not you can try Audacity. It's not the easiest way as you will probably have to do them one by one. Link to comment Share on other sites More sharing options...
