arvitis Posted January 4, 2014 Share Posted January 4, 2014 hi guys... new here and hvaing a big problem...maybe you ve got some ideas. i'm trying to setup an ml 350p gen8 that has a p420i controller embeded. i bought 4 wd reds each one 1tb and a kingston ssd. the ssd runs fine.i've installed windows server 2012 foundation..everything looks ok... when i attach the 4 wd's..the array controller fails to start and i can not access it even through hp's storage administrator. if i have only he ssd attached,everything is ok.... i'm trying to find a solution from 9 o clock i the morning......... any ideas??????????? Link to comment Share on other sites More sharing options...
ikon Posted January 4, 2014 Share Posted January 4, 2014 It could be that 1 of the drives is giving you grief. You need to ensure that all 4 of the drives are individually good. What I mean is, attach each of the Reds, one at a time, to another PC, and ensure they are each discoverable and useable. My ideal way to do this is to put a drive into a USB 'toaster' dock, like this: http://www.thermaltakeusa.com/products-model.aspx?id=C_00001642. Link to comment Share on other sites More sharing options...
arvitis Posted January 4, 2014 Author Share Posted January 4, 2014 wow..thanks for the fast reply....!! i've already have done this and also formaed them.. i did not mention that the first time i booted i saw them all...strange hm? Link to comment Share on other sites More sharing options...
ikon Posted January 4, 2014 Share Posted January 4, 2014 OK, I guess that rules out any DOA drives. Have you tried just using 1 or 2 drives, you know, as a test? Also, I don't know if this applies, but did you try any of the drives before they were partitioned and formatted? I assume you did, but just want to be precise. Link to comment Share on other sites More sharing options...
arvitis Posted January 4, 2014 Author Share Posted January 4, 2014 yes ikon... i also changed bays,tried with each one separate...keeps the same behavior...i'm at a dead end... what do you think about bios settings???maybe i missed something.. Link to comment Share on other sites More sharing options...
ikon Posted January 4, 2014 Share Posted January 4, 2014 Sorry, can't help with that. I don't have a G8 box to play with (I've only set up a Gen8 DL360p and that was strictly a WS2008r2 + SQL Server 2008r2 setup, and it came with all the SAS HDDs already installed). Hopefully, someone else can chime in. Link to comment Share on other sites More sharing options...
arvitis Posted January 4, 2014 Author Share Posted January 4, 2014 thanks again for the reply!!i'll keep looking! Link to comment Share on other sites More sharing options...
schoondoggy Posted January 4, 2014 Share Posted January 4, 2014 How do you have the five drives attached? Are you able to enter the HP ACU when booting? Latest BIOS and firmware on all? Link to comment Share on other sites More sharing options...
schoondoggy Posted January 4, 2014 Share Posted January 4, 2014 thanks again for the reply!!i'll keep looking! try running the offline HP SSA: http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/swdDetails/?sp4ts.oid=5295170&spf_p.tpst=swdMain&spf_p.prp_swdMain=wsrp-navigationalState%3Didx%253D%257CswItem%253DMTX_50309f0541d14018bb674c59b8%257CswEnvOID%253D4064%257CitemLocale%253D%257CswLang%253D%257Cmode%253D%257Caction%253DdriverDocument&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken Link to comment Share on other sites More sharing options...
schoondoggy Posted January 4, 2014 Share Posted January 4, 2014 yes ikon... i also changed bays,tried with each one separate...keeps the same behavior...i'm at a dead end... what do you think about bios settings???maybe i missed something.. Have you checked the BIOS to see if the 420i is enabled? Link to comment Share on other sites More sharing options...
