Sign in to follow this
TomJones
Weird write speed problems with N54L
TomJones
Dear all,
while the N54L is definitely an awesome machine, I have quite a bit of trouble with the write speeds of the server (both internal writes from one disk to another and also via GBit Ethernet).
What confuses me is that the write speed increases over time.
I did a write benchmark and here are the results:
First run
Second run
Third run
The server is running Win 7 64Bit with only the AMD Sata drivers installed, 6GB of Ram and stock BIOS.
Does anyone have any idea how the strange behaviour in terms of the write speed can be explained and "fixed" such that I can always ~100MB/s from the beginng?
Best regards,
Tom
Edited by TomJones
schoondoggy
What kind of drive are you running this benchmark on?
TomJones
These are 2TB ST2000DL004 drives
jmwills
Do these three tests represent the exact same data sets?
TomJones
Yes
The tests were carried out with 2 minutes of pause between successive tests.
Actually, if you think of caching effects - no, that's not the case. I am currently copying (over GBit Ethernet) a ton of data to the drives and the speed is 110MB/s, but it was very slow in the beginning of the transfer (like 20MB/s)
Edited by TomJones
