PCI-e USB 3.0 Card
C4rl
I’m in the process of setting up my new HP N54L, I’ve installed WHS 2011 and it’s currently down loading 111 updates, all 699mb worth.
I have three 3TB drives to go in it once it’s completed all the updates.
I plan to back up specific shared folders, Music and Films mainly to an external 3 or 4TB USB 3.0 drive, kept off site and also mirror one of the internal drives to do the same within the N54L.
Thus I’ll obviously need a PCI-e USB 3.0 card, I’ve carried out several searches of the forum, followed numerous links to cards mentioned and nearly all are no longer available. Can anyone recommend a card that’s still available in the UK that will definitely work within the N54L without problems and require no alterations on the power side?
Thanks in advance for any help.
Carl.
Thanks for your continued input schoondaddy its very much appreciated  I'll check out their website and try a track down a seller in the UK.
Carl :)
Physically that one should work, it looks like it comes with the LP bracket. You will need to find adapters to get to the SATA power connection.
Edited by schoondoggy
