RAC v1.3 will set BMC Settings to default
Sokoban
Hi
I runníng Windows Server 2012 Essentials in my HP Proliant MicroServer NL40
I have problem to login to my RAC Card via web. I have setup the Bios the IP addresses.
I am trying to set BMC Settings to default, I have done following.. in Windows Method.
  1. Copy the files ...Update, Socflash and astio.sys (x64) in C:\Windows katalog
  2. Running the command i dos prompt in Windows --> update.bat
C:\Windows>Update.bat
C:\Windows>rem Phrixus iBMCX FW Update Utility Rev 1.0
C:\Windows>socflash if=all.1.3.bin gpio_b=c40 gpio_f=c41
ASPEED SOC Flash Utility v.1.03.02
[Error]Cannot load Windows WDM Driver Properly!!
[info] Please make sure the driver signature enforcement has benn disabled in Windows 2008 x64
How I will solved that ?
  • 7 months later...
Does not work, seems impossible to update firmware from running Windows, back to DOS USB stick (for which I needed to connect monitor & keyboard :( )
sebus
