1st Build - multiple problems
ChrisPbass
If you check that 8-pin connector closely, you should find that it can actually come apart into 2 pieces. Also, make absolutely sure you are not using a connector that's labelled PCI-E -- it's for add-in cards, like video controllers.
You are correct ikon.  I did look it up on Corsair's site and saw that I needed to split it apart.
I can't quite read it as it's plugged in but the PSU comes with 2 PCI-e cords and they are not connected to anything.
The PCI-e connectors are 6 pin.
Thank you for your help.
