snapper 38 Posted September 3, 2013 Share Posted September 3, 2013 Hi Has anyone measured the power consumption of the G8 micro server? Would like to upgrade from the N54L, but wondered if the new gen was a lot more power hungry... I've tried google, but can't find anywhere that lists real-world figures. Cheers Link to post Share on other sites
psikey 32 Posted September 3, 2013 Share Posted September 3, 2013 Hi Has anyone measured the power consumption of the G8 micro server? Would like to upgrade from the N54L, but wondered if the new gen was a lot more power hungry... I've tried google, but can't find anywhere that lists real-world figures. Cheers If you use legacy or AHCI with an SSD for the OS and 4 x 3TB WD RED drives and let the drives go into standby then it pulls ~28w but fan control is not ideal and stays above 33% which is too loud for a typical home lounge use. When the drives are spinning with CPU idling it pulls around 42w. In RAID mode the fan stays at ~6% but then drives don't spin down so pulls 42W. In Hibernation it pulls about 3w which is more than the G7 series. If using the add in RAID card P222/512 it then pulls around 62w. Link to post Share on other sites
ikon 439 Posted September 3, 2013 Share Posted September 3, 2013 Thanks for the info psikey. I could live with 62W... like leaving 1 light bulb on. Link to post Share on other sites
snapper 38 Posted September 6, 2013 Author Share Posted September 6, 2013 If you use legacy or AHCI with an SSD for the OS and 4 x 3TB WD RED drives and let the drives go into standby then it pulls ~28w but fan control is not ideal and stays above 33% which is too loud for a typical home lounge use. When the drives are spinning with CPU idling it pulls around 42w. In RAID mode the fan stays at ~6% but then drives don't spin down so pulls 42W. In Hibernation it pulls about 3w which is more than the G7 series. If using the add in RAID card P222/512 it then pulls around 62w. Many thanks for the info - it matches exactly what config I'm planning 28w is quite respectable for idle Link to post Share on other sites
Jason 84 Posted September 6, 2013 Share Posted September 6, 2013 Now have me curious as to my WS2012E server idle usage. On next reboot, will install my wattage meter. It's a workhorse ... Core i5 IB, 2 SSDs for OS mirror, 8 WD Red HDD RAID 6. Link to post Share on other sites
OctavianH 13 Posted May 21, 2015 Share Posted May 21, 2015 (edited) Did anyone measured the power consumption after upgrade of the CPU to Xeon 1265L V2? Edited May 21, 2015 by OctavianH Link to post Share on other sites
