$249.99 HP ProLiant N54L G7 MicroServer
Joe_Miner
$249.99 After Promo Code and MIR HP ProLiant G7 N54L MicroServer Server System AMD Turion II Model Neo N54L 2GB 250GB LFF Operating System None 704941-001
Price is $289.99 with Promo Code EMCXMVN226 then drops to $249.99 after $40.00 MIR
EDIT: Counting back I realized this was my 2,000th Posting -- I hope someone jumps on this deal :)
Edited by Joe_Miner
Congrats John on your 2000th post!  I tried to take advantage of the deal and did not get the pricing  you outlined with the code (only $50 instant credit), with rebate it was a total of $299 in my shopping cart.  Is it for another time?  I am not sure what I am missing.....   I was hoping to join the esteemed microserver club I keep hearing about....  :)
Thank you,
Chuck Thompson
Thank you,
Chuck Thompson
The $50 instant credit you get without doing anything.
Near the bottom Left of the "ShoppingCart" it says Apply Promo Codes then in RED it says Promo codes have usage limitations that require you to enter your email address to enable Promo Codes.
You will need to enter your e-mail address associated with your account then enter the PROMO CODE  EMCXMVN226 which will take another $50 off the Grand Total Price bringing you down to $289.99 (assuming you chose the Free Shipping)
You will next need to go back to the page http://www.newegg.com/Product/Product.aspx?Item=N82E16859107921 and on the Right of the page it will say: Receive a $40 prepaid card by mail from Newegg! Expires on 9/2/13 and below that will be a link to a PDF form you will need to print out and complete then mail in to get your $40 Rebate (in 2-3 months).  Final Price after Rebate will be $249.99
No Problem. Welcome to the Club!!  You'll have to post some pics when it arrives :)
Edited by Joe_Miner
Congrats on 2000 HSS Master John Stutsman!
Congrats!! John!!
You are quite Prolific!
:P
Congrats John on your 2000th post! -snip-
Thanks guys!  (and Thanks for reading all 2,000 of those posts :) )
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • E3000
      By E3000
    • chickenlip007
      By chickenlip007
      Hi Guys, have a strange issue whereby my N54L won't turn off, it just reboots. The same behavior is seen when using Windows or Vmware, when shutting down, the server proceeds to start the shutdown process but powers itself up again immediately. I have tried resetting the Bios, removed the board and all components, re-installed and still the same.
      I moved the mainboard into a spare Microserver Chassis with the same result (to rule out any cabling issues). I have changed the RAM modules as well, with no luck.
      It is worth mentioning that the onboard NIC no longer works either, I have replaced with a PCIex card that works fine. Holding down the power button for 5 seconds will turn off the server but immedately starts back up when it is released. I have compared BIOS settings to another working Microserver in my LAB, same results.
      I am honestly out of ideas, spent way too many hours scratching my head over this one. the only way to get it to stay off is wait till the splash screen loads then pull the power plug, which is not ideal.
      Anyone else have any ideas?
      thank you!
    • E3000
      By E3000
      Hey guys,
