External Box of Drives for eSATA Port-Multiplier and USB 3.0
Joe_Miner
I was wondering what external boxes people are using successfully with eSATA port multipliers and are there any dual purpose that have worked well with USB 3.0.  I was thinking/hoping for something that would work with DrivePool or DriveBender on a N40L/N54L now on the eSATA Port-Multiplier and the Gen8 USB3.0 later…………….
What about the Sans Digital MobilSTOR MS4UM+B http://www.amazon.com/dp/B006MB9B3S
Or the SilverStone Teratrend TowerStor TS431U http://www.newegg.com/Product/Product.aspx?Item=N82E16817256095
I have been using an older model Sans Digital 4bay box for about 4 years. It has worked faultlessly.
Pretty sure Diehard is still using his too.
I am still using and old Sans Digital 4 bay box as well.  It was giving me problems at first as it was dropping the connection under heavy load but I eventually found the fix which was to disable the "Link State Power Management".
It has been working perfectly for the last few years.  I have loaded it up with RED drives and have no issues at all.
    • Haxsource
      By Haxsource
      Good afternoon folks!
      I have a question I was wondering if someone would know about. I have a Microserver Gen 8 with Vmware ESXI 7 currently installed on the MicroSD with AHCI enabled instead of RAID mode (dont find anything usefull in raid mode in my current setup other than booting from ODD, which I can just use as another Datastore instead).
      With that context being said, Im trying to enable the Agentless Management Service from the ILO with the drivers on the Vmware ESXI 7, but unfortunetly after installing and trying to start the service with:
      /etc/init.d/hp-ams.sh start
      I get the following error:
      /opt/hpe/ams/amshelper: error while loading shared libraries: libnicmgmt.so.0: cannot open shared object file: No such file or directory
      Makes sense following the Vmware ESXI HPE support matrix, since its only supported until Vmware ESXI 6.5U2 Pre-gen. But I´ve been reading lots of people having working setups doing the following:
      Install Vmware ESXI HP Custom Image 6.5U2 -> Offline Update to Vmware ESXI 6.7.
      I was wondering if installing HP Custom Image 6.5U2 with the drivers Agentless Management Service working and doing a full upgrade to ESXI 7.0 would do the trick, since its an upgrade not a clean install...so libraries should stay supporting older drivers installed.
      Does this make any sense?? Has anyone gone trough this alredy?
      Thanks!
    • netware5
      By netware5
      ***CRITICAL*** iLO 4 update available here. HPE requires users update to this version immediately. Potential vulnerabilities in network stack.
      VULNERABILITY SUMMARY
      A potential security vulnerability has been identified in Integrated Lights-Out 5 (iLO 5), Integrated Lights-Out 4 (iLO 4), and Integrated Lights-Out 3 (iLO 3) firmware. The vulnerability could be remotely exploited to cause memory corruption.
      HPE has released updated firmware to mitigate these vulnerabilities.
      References: CVE-2020-27337
    • oldwhs12
      By oldwhs12
    • AVsonyfan
      By AVsonyfan
      Tips:
    • hhvdwatt
      By hhvdwatt
      Hi I am new to forum.
      I have an HPE 40L Microserver and would like to upgrade the motherboard to something a bit more modern.
      From what is can find on this topic it would appear that the motherboard is mini-ITX like but not exactly. Has anyone ever resolved upgrading this with something new that works or should I just replace the server?
      Thx in advance
