Dual fan, four 2.5" hard drive bracket $6.99
schoondoggy
Nice find but I'm looking at this one.  A little more expensive but the cabling is a lot cleaner.
Edit:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817986007
(oops)  :unsure:
That is definitely a nice price point.
I have used several of these;
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994095
They support SAS & SATA, all metal drive trays, but they are twice the price of the Vantec.
Can I get same 4x 2.5" bay but with port multiplier backplane?
I'd not going to use SSDs in my project. So 1x SATA 6G port should provide enough bandwidth I expect.
Nighter there is space to fit PCI-E SATA expansion card in my project. So I'm also looking for Mini-ITX board with onboard controller supporting port multipliers. Any suggestions here? Would Intel DQ77KB or S1200KPR meet this requirement?
Edited by Hardened
I just got one of these from Geeks.com. It holds four 2.5" drives in a 5.25" bay. It is spaced to hold four WD VR drives and has two fans to keep them cool. The face plate is plastic, but all in all it seems well built.
http://www.geeks.com/details.asp?InvtId=2-FAN-HDD-BRACKET
By the looks of those fans, I think they're bound to make a lot of noise.
