revengineer Posted June 30, 2013 Share Posted June 30, 2013 Now that I have moved away from my WHS v1 I am no longer stuck with with using non-advanced format drives, and I am looking into using 3 TB instead of 2 TB drives. In the past I have bought exclusively WD drives. I have had good luck with them, but was using the WDIDLE3 tools to disable intellipark to reduce the load cycle. Using this tool on a new drive type is always risky as none of the newer drives are officially supported by this tool. So I am looking at alternatives, and the Seagate ST3000DM001 seems to be very close in price. Does anybody know whether this drive has an intellipark-like feature and, if so, whether this feature can be disabled? Link to comment Share on other sites More sharing options...
pcdoc Posted June 30, 2013 Share Posted June 30, 2013 The ST3000 does not use intelipark as it is a more performance based drive using 7200. I have 13 of these and have only had one failure about 20 days after the install. They are a bit noisier but the difference in performance if very noticeable. Overall I really like them. Link to comment Share on other sites More sharing options...
revengineer Posted June 30, 2013 Author Share Posted June 30, 2013 Thanks for your input, PCDoc. Learning in a different thread that the new WD Green's can no longer be tweaked with WDIDLE3, I may give these a shot. I do not need the performance gain, but I like that there is no artificially increased wear through unnecessary load/unload cycles. If I hate the noise I will have to consider whether the $30 Red premium is worth the prices. Link to comment Share on other sites More sharing options...
