jmwills 284 Posted June 25, 2013 Share Posted June 25, 2013 It should work.... Link to post Share on other sites
Shoop 0 Posted June 25, 2013 Author Share Posted June 25, 2013 Okay, I forwarded the ports to the second server. It definitely is not working from my local network. I tried using both the wan IP as well as the domain name with the :8443 port extension. I will try thisfrom my work tomorrow. Link to post Share on other sites
jmwills 284 Posted June 25, 2013 Share Posted June 25, 2013 Of course it won't work from inside your local network....what's the purpose?..You are already past the router and your browser cannot understand where to go. Link to post Share on other sites
ikon 439 Posted June 25, 2013 Share Posted June 25, 2013 Although it can be made to work from inside you LAN, it's often difficult to get all the stars aligned for it to work. The important issue is to get it to work from the Internet. If you have a phone that has Internet Sharing, you can test it that way. Otherwise, you can do it from work, use your laptop from a local business such as a restaurant, have a friend try to get to the login page, etc. Link to post Share on other sites
jem101 17 Posted June 25, 2013 Share Posted June 25, 2013 I generally test it with a phone, make sure that WiFi is off so you really are using a 3G or 4G connection. John Link to post Share on other sites
Shoop 0 Posted June 25, 2013 Author Share Posted June 25, 2013 Still no dice. I tried both the IP address as well as the actual domain name I registered with Microsoft. It seems like either way should work but I get nothing. Link to post Share on other sites
jmwills 284 Posted June 25, 2013 Share Posted June 25, 2013 What is the error you get when using the IP Address appended by the port number? Link to post Share on other sites
ikon 439 Posted June 25, 2013 Share Posted June 25, 2013 I generally test it with a phone, make sure that WiFi is off so you really are using a 3G or 4G connection. John Good point. I do that automatically, so I never think about it anymore Still no dice. I tried both the IP address as well as the actual domain name I registered with Microsoft. It seems like either way should work but I get nothing. If you don't mind, perhaps you can give a couple of us your WAN IP address in a PM and we'll see if we can get to the login page. We don't need any login credentials (and I don't want any). We would just see if the login page comes up. Link to post Share on other sites
Shoop 0 Posted June 25, 2013 Author Share Posted June 25, 2013 I'm not getting any errors. It just sits there waiting for a response from the IP. I didn't even think to use my phone.lol I would rather not give my ip address for various reasons. Link to post Share on other sites
jmwills 284 Posted June 25, 2013 Share Posted June 25, 2013 Have you looked in the event logs? Maybe your router can't handle this. That's all I can add. Link to post Share on other sites
