Network problem on my N36L
kaelken
Hi all,
I have run into an odd problem on my Hp microserver model N36L.
For some reason, the folders that I have shared to my homegroup, seems to become unavailable when some time passes.
I have not been able to find an exact patter in this.
I can generally get it respond again, if I remote desktop to the server and then access a folder on the network.
The problem is that I have an apple tv 2 connected to it, and when the folders become unavailable, I need to restart the server, for the apple tv 2 to be able to see the folders again.
Do you guys have any idea what could be my problem here ?
p.s I am running a normal win 7 installation, since I am a little new to setting up this server.
Hope you guys can help.
Thanks a lot.
Kaelken.
There is a setting on the NIC to save power.  Go to Network Connections>Right Click the Adapter and go to Properties>Configure>Power management Tab and see if that box is checked.  If so, uncheck it.
I have that box unchecked.
Although you say that it is a setting on the NIC ?
My network card is a Broadcom Netxtreme gigabit Ethernet ? Am I using a wrong driver on this ?
What OS?  You mentioned Win7, is the OS allowed to sleep?
If the NIC is working, leave the driver alone....
im using win 7, and I have changed the power plan so it shouldnt be able to sleep.
I found a new network driver that I have just updated too, to see if that fixes the problem.
Thanks for posting that, the solution is quite interesting and not something I knew about as I'd never tried to use Windows 7 (or any other desktop OS) for long term file serving.
It does illustrate a very important point though, if you want a machine to act as a proper server, then use a proper server OS. It might look similar to a desktop OS but all sorts of stuff is different under the hood.
