Using Tversity Pro but need help with MPG - No sound
RWG3
I have TVersity set up on a WHS2011 machine with WMP12 and ffdshow installed.  I chose TVersity because I saw lots of good reviews and it worked to serve media outside my network on a browser.  It works with PC's any DNLA player and Ipads and Iphones.  It transcodes on the fly but details re: Codecs and settings are very thin.
It is transcoding WMV files to my ipad as TS and to windows browsers as FLV both are working fine.   It tries to do the same with MPG files... and they look great but there is no sound on either the Ipad or the windows browsers for MPG files. The MPG files play fine on WMP on the server machine. I suspect it's a setting on FFDshow or a missing codec... but I don't know where to start looking.
Any thoughts?
Most people try to avoid installing Codecs on their servers.  It sounds like it is actually using the wrong codec to encode the MPG file but your server can play it because the codec is local to that machine.
