Chris_ni 0 Posted May 22, 2013 Share Posted May 22, 2013 Hi, First time posting. I have an HP Proliant N40L and have installed an HP Smart Array P410 RAID PCI-e card, however the system won't detect the actual card. Is there a BIOS update required or has anyone had a similar issue with the N40L detecting RAID cards? Regards, Chris Link to post Share on other sites
schoondoggy 895 Posted May 22, 2013 Share Posted May 22, 2013 (edited) Do you have the stock BIOS or modified BIOS on the N40L? Have you tried the P410 in another system to confirm that it works? Edited May 22, 2013 by schoondoggy Link to post Share on other sites
cskenney 155 Posted May 22, 2013 Share Posted May 22, 2013 This topic has some info that might be helpful http://homeservershow.com/forums/index.php?/topic/4906-p410-for-a-micro-server-quick-q/ Here is some additional information about the P410 http://homeservershow.com/forums/index.php?/topic/5070-hp-smart-array-p410-controller-34tb-drives Link to post Share on other sites
schoondoggy 895 Posted May 22, 2013 Share Posted May 22, 2013 You can use the offline configuration utility to see if it can find the P410 as well; http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=329290&prodSeriesId=3883890&swItem=MTX-3c888073127c4c65b7bd8559eb&mode=3 Link to post Share on other sites
schoondoggy 895 Posted May 25, 2013 Share Posted May 25, 2013 I forgot to ask, do you have the battery for it as well? Link to post Share on other sites
Joe_Miner 254 Posted May 25, 2013 Share Posted May 25, 2013 If you did the BIOS-MOD and Disabled the SATA/IDE Port Combining that will also Disable your MicroServer seeing the P410 -- Disabling SATA/IDE Port Combining withBIOS-MOD Disables MicroServer Seeing P410 This also may be useful -- HP Support HP Guides HPSmart Array Controllers for HP ProLiant Servers User Guide Link to post Share on other sites
