xbmc library sync using mysql
chris888
I have multiple devices on my LAN using xbmc and I wanted to have one central database to store library information and watched/unwatched status'. I also though it'd be cool if I could pause a movie on one device and pick up where I left off using a different device :D
I found mysql to be the perfect tool for this but it took a while to find out how to integrate it with xbmc, so I thought I'd share how I managed to get it to work so hopefully it'll help you guys out...
My Server OS: Ubuntu Desktop 12.04LTS
1 - On your server install mysql server
sudo apt-get update
sudo apt-get mysql-server
2 - Secure mysql sever installation
sudo mysql_secure_installation
follow the steps on the screen
3 - Configure mysql server
sudo gedit /etc/mysql/my.cnf
Scroll down to 'bind address' & replace IP with IP address of server
4 - Set up xbmc as a mysql user and set privilages
mysql -u root -p
create user 'xbmc' identified by 'password';
(edit password)
grant all on *.* to 'xbmc'
ctrl+d to exit
5 - Open firewall port 3306 on server
6 - On your server create and edit advancedsettings.xml file
Linux:             /home/"user"/.xbmc/userdata/advancedsettings.xml
Mac:               /Users/"user"/Library/Application Support/XBMC/userdata/advancedsettings.xml
XP:                 Documents and Settings\"user"\Application Data\XBMC\userdata\advancedsettings.xml
Vista/Win7:   Users\"user"\AppData\Roaming\XBMC\userdata\advancedsettings.xml
iOS:                /private/var/mobile/Library/Preferences/XBMC/userdata/advancedsettings.xml
Android:        Android/data/org.xbmc.xbmc/files/.xbmc/userdata/advancedsettings.xml
OpenELEC:  /storage/.xbmc/userdata/advancedsettings.xml
Add the following and edit IP address & password
<advancedsettings>
    <videodatabase>
        <type>mysql</type>
        <host>server.IP</host>
        <port>3306</port>
        <user>xbmc</user>
        <pass>password</pass>
    </videodatabase>
    <musicdatabase>
        <type>mysql</type>
        <port>3306</port>
        <user>xbmc</user>
    </musicdatabase>
</advancedsettings>
7 - On your server, add all your media sources and fully update your xbmc library
8 - Check mysql database entries to make sure xbmc is infact using mysql
mysql -u root -p
show databases;
You should see MyVideos & MyMusic databases
9 - On the client install a mysql connector
For a Ubuntu client open terminal and use:
sudo apt-get update
sudo apt-get install mysql-client
10 - Open firewall port 3306 on client
11 - Copy the advancedsettings.xml to the client
If your using Linux you can use SSH
scp /home/"user"/.xbmc/userdata/advancedsettings.xml "user"@client.IP:/home/"user"/.xbmc/userdata/advancedsettings.xml
12 - If your sharing Thumbnails as well you need to copy the textures.db to your client too in order for them to automatically sync.
scp /home/"user"/.xbmc/userdata/Database/Textures.db "user"@client.IP:/home/"user"/.xbmc/userdata/Database/Textures.db
13 - Load xbmc on your client and and check your library.
Has it worked? Leave a post below and let us know :D
For more info on synchronising xbmc libraries check out this xbmc wiki page:
