LoneWolf
ProLiant Microserver Remote Access Card Firmware Update
ikon
Do you connect 2 Ethernet wires to your Microserver, one to the built in NIC and the other to the Remote Access Card?
That would be the normal routine. The RAC port is really just for that; remote access.
riahc3
Note:  I was unable to update my Remote Access Card through its web UI, forcing me to use the SoC flash utility on a bootable USB key with FreeDOS.  The WebUI method would start to show updating, and just sit on that screen and never finish.
Could you explain this a bit better? What exactly is the "SoC flash utility" and how can you set it up?
I know how to make a simple bootable USB key but the rest...
Never mind. I was opening the wrong file and when I downloaded and open the correct file, I see the utility is included :)
Edited by riahc3
sebus05
The good news -the BIOS updates the security certificate on the card, and there's a few bug fixes.  The bad news -there really isn't anything new in the way of features or interface changes.  I do hope it improves on the stability of the RAC (which wasn't perfect), and I hope I can eventually get port forwarding set up so I can access the RAC from outside my LAN, as I've been having issues getting that working, but that could be an unrelated issue.
Well, do not know about BIOS, but firmware upgrade to 1.4 certainly does NOT update certificate.
Of course I can get one generated from my own EnterpriseCA, but 1.4 seems to have the same bug like 1.2 where all I get while trying to upload generated .cer is error: "Certificate upload failed"
Anybody had any success with certificate?
sebus
edit:
One needs to download Base 64 encoded from CA (DER encoded does not work)
Edited by sebus05
Taffeys
Is there a new RAC firmware 1.4? I have 1.3 but my N54L is now out-of-warranty and cannot find this new firmware.
ikon
Perhaps you're getting caught by the recent change by HP to require an active support contract in order to have the right to download firmware updates??
Taffeys
Very possible... that's why I asked sebus05. My RAC seems to work OK, but sometimes not, with 1.3 and if and when I get my T20 built-out and IF AMT 9.0 works on it I'll turn the N54L into a HTPC and dump the RAC anyway.
Edited by Taffeys
sebus05
No idea, I have no contract & just browsed drivers page for the Microserver
Returns download for firmware at HP FTP site
Windows install is impossible, had to do it from USB bootable DOS stick
sebus
Edited by sebus05
Taffeys
sebus
Thanks sebus05! I searched the drivers page too but never found this RAC firmware update. Maybe I couldn't find it because I was logged-in to the HP support system.
Anyway, I updated the RAC firmware through the RAC Web GUI as I was typing this, it worked fine. I did the USB DOS boot update when I upgraded to 1.3 (I don't run Windows on my N54L).
Startech apparently had one, but it appears to be discontinued, and was PCI.  Unlikely you'll find it.
http://www.startech.com/PCI-Server-Remote-Control-Internal-IP-KVM-Card~SV1110IPPCI
I found this card in the US from some obscure vendor, asking price is ~$590US  :o
sebus05
Tried all sorts of OSs on this machine, but nothing makes it as usable as Server 2012 R2. And that comes from person that would rather run SLES 11.x normally.
Edited by sebus05
