Stablebit Drivepool for WS2012e
hopester
I found an issue moving shares onto the pool via the dashboard and then Alex posted an update:
Server 2012 Essentials is not one of the 10 supported operating systems (yet).
Windows Server 2012 should work fine. I'll look into 2012 Essentials compatibility at my earliest convenience.
Edited by hopester
It's probably just a coding problem where an os version id is pulled and does not match up against a list of authorized os versions. Just my guess...
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
BETA 2.0.0.160
* [D] Server 2012 Essentials compatibility.
* Link in Server 2012 Essentials Dashboard to launch DrivePool UI from the Server Folders tab.
Well that did not take long :)
I'm having major growing pains with 2012 (unrelated to DrivePool)
http://forum.covecub...06#Comment_3706
I thought I would be instantly happy with 2012 and DrivePool but the Domain thing makes it a nighmare for sharing. (for people that don't want to join the domain, or use the connector even with hack)
DrivePool on 2012e is working perfect, but I might go to Windows 8 with DrivePool instead if I can't over come the above link problem
Edited by JazJon
Can you elaborate on how sharing in a domain is a nightmare? I find it easier than in a workgroup. Maybe I'm just used to it from doing it in an enterprise.
