mailman1988 Posted January 30, 2013 Share Posted January 30, 2013 I had a DLink Dir615 (150mbs). I purchased a Dir615RE (300mbs). Since these unit's are virtually the same I saved the Configuration file from the old one, then loaded it onto the new one. All went well. All my static IP's and devises ported over just fine. The problem that exists is that prior to the switch, I was able to remote access my V1, now I cannot. When I check the router, all looks good. When I run the remote access script from settings, I get an error stating that the web page is Not available. The Domain exists, the Hotmail address is good, so what am I missing? I'm thinking it might have to do with the Mac address somewhere, but??? Ideas Thanks Link to comment Share on other sites More sharing options...
ikon Posted January 30, 2013 Share Posted January 30, 2013 Remote Access from inside your LAN or outside? Link to comment Share on other sites More sharing options...
jmwills Posted January 31, 2013 Share Posted January 31, 2013 Did you reboot everything? If not, do so. Link to comment Share on other sites More sharing options...
Renny Posted January 31, 2013 Share Posted January 31, 2013 With V1 I often got an error but web access was available. You could try releasing your address too and then simply claim it back and set up from there Link to comment Share on other sites More sharing options...
mailman1988 Posted January 31, 2013 Author Share Posted January 31, 2013 This is the messages I get when running the remote access configuration routine. Status:Configured but not verified Connection to windows live-Pass Updating live customer domains-Pass "Verifying your website is available from the Internet"-Fails "Verifying remote access is accessable from the Internet"-Fails Verifying windows live custome domain records-Pass I've tried reboting everything, several times. I've tried the Repair option "Configuring your router with UPNP Standards" I get an Exclamation point. UPNP is turned on "Verifying that your remote Web site is available from the Internet:-Fails Please explain Releasing my address. Are you saying to Re-configure my Domain Link? Link to comment Share on other sites More sharing options...
jmwills Posted January 31, 2013 Share Posted January 31, 2013 First of all, turn of UPNP on that router. It is a SERIOUS secruity issue. Configure everything manually. Link to comment Share on other sites More sharing options...
Renny Posted January 31, 2013 Share Posted January 31, 2013 Mailman, this is taxing my memory, but I have always manually forwarded the ports on my router as JMW suggests On the release your address issue. I too could not get remote access to work after a router change. I found that releasing the web address XXX.homeserver.com and then setting up the address again using the same address got remote access humming again Link to comment Share on other sites More sharing options...
ikon Posted January 31, 2013 Share Posted January 31, 2013 renny, this really points to a DNS issue, and it seems that it's at Microsoft's end. What I suspect is going on is MS is acting as the Domain Name Server for these addresses. I'm thinking MS registers your WAN address when you first set up Remote Access. Then, when people try to access the web page using the URL, MS feeds the registered IP to the requestor. The issue I think is that MS is NOT acting as a Dynamic DNS (DDNS). This means, when the WAN IP changes, such as when a cable or DSL modem, or internet gateway/router is rebooted, MS no longer has the correct address. Releasing the registration and redoing the process would indeed get the new address into the MS server. The problem I have with this thinking is the D-Link router. Mailman1988 hasn't actually said that the router is being used as his internet gateway. If it isn't, everything I just posted is nonsense. So, Mailman1988, is the new router also your internet gateway? Link to comment Share on other sites More sharing options...
mailman1988 Posted February 21, 2013 Author Share Posted February 21, 2013 So I re-established my Domain with MS. I did a Release, then registered again. Same problem still exists. My D-Link is being used as a Router. Maybe there is a port issue? I am having difficulty figuring out what ports I have opened and how to open more for the server in my port forwarding. When I try to put more to open, I get error messages (from D-Link) saying they are already open or conflict with other ports. Hmmmm. When I typed the port forward values as "80,455,4125" I would get an error. These port numbers I got from the MS site. Thanks for you help in advance. Link to comment Share on other sites More sharing options...
ikon Posted February 21, 2013 Share Posted February 21, 2013 I don't have the exact same router (it's a DIR628), but most of the D-Link routers have very similar interfaces. You should be able to see all the forwarded ports by logging into the router's web interface and going to Network Settings/Advanced/Port Forwarding. Link to comment Share on other sites More sharing options...
