ikon Posted October 22, 2013 Share Posted October 22, 2013 There are two LP brackets. To use all three ports you need to use both brackets. When I installed a HD5450 in the N40L I just disconnected the VGA connector so that I wouldn't need the VGA LP bracket for that connector -- I was only going to use the HDMI for the HTPC functions anyway. The Pictures at Newegg clearly show two LP Brackets which was the same as what I got with the HD5450. http://homeservershow.com/hp-proliant-n40l-microserver-hdmi-video-card-hss-meet-2013.html Ah. Got it. It's the old 'double-wide' video card trick. Wouldn't work too well in the N40L, at least not if you still wanted to use the only other slot. I still don't think it's clear enough what's going on. I only saw 1 photo with the brackets, and it was just the overall box contents photo. There should be a photo of the brackets mounted, to show how it works. Link to comment Share on other sites More sharing options...
Scoobiedoo79 Posted October 22, 2021 Share Posted October 22, 2021 Hi All, I'm looking for a graphics card for my n40l and the nvidia geforce GT520 has been recommended to use. Is this the best of the bunch for my server or is there others I can use? I've seen quite a few GT520's but not many with the low profile bracket. Thanks in advance. Link to comment Share on other sites More sharing options...
schoondoggy Posted October 23, 2021 Share Posted October 23, 2021 5 hours ago, Scoobiedoo79 said: Hi All, I'm looking for a graphics card for my n40l and the nvidia geforce GT520 has been recommended to use. Is this the best of the bunch for my server or is there others I can use? I've seen quite a few GT520's but not many with the low profile bracket. Thanks in advance. Depends on your budget and what you are trying to achieve. I think you would want to look for a low profile single slot width card. Cards based on the GT 1030 are likely the fastest available today. If a workstation card will work there are several NVIDIA Quadro cards that are LP single slot cards. 1 Link to comment Share on other sites More sharing options...
Scoobiedoo79 Posted October 23, 2021 Share Posted October 23, 2021 12 hours ago, schoondoggy said: Depends on your budget and what you are trying to achieve. I think you would want to look for a low profile single slot width card. Cards based on the GT 1030 are likely the fastest available today. If a workstation card will work there are several NVIDIA Quadro cards that are LP single slot cards. Thanks for the reply. Cards basically being installed to allow plex a transcode files better. Budget wise I was thinking probably about £50 ish give or take. Link to comment Share on other sites More sharing options...
schoondoggy Posted October 25, 2021 Share Posted October 25, 2021 On 10/23/2021 at 7:14 AM, Scoobiedoo79 said: Thanks for the reply. Cards basically being installed to allow plex a transcode files better. Budget wise I was thinking probably about £50 ish give or take. This is a good tool to help pick a card: nVidia Hardware Transcoding Calculator for Plex Estimates (elpamsoft.com) 1 Link to comment Share on other sites More sharing options...
