r.mcadams@mchsi.com
Selling WMC Equipment - HDHomerun, Ceton Echo
Drashna Jaelre
Would only take a couple of minutes to set up and configure it enough to test. If it doesn't work, then only a small amount of time lost. If it works... only a large amount of time lost due to tweaking it to be exactly like you want. :P (optional, but ... you know you will)
ImTheTypeOfGuy
I thought XBMC couldn't play live TV or something that made it less appealing than Media Center. I have never looked at it because of it.
ikon
Not sure about that, not that it would be a concern for me anyway - the only real way to get TV in my area is cable, and they require you use their STB.
ikon
I installed XMBC 12RC3 about an hour ago. From what I've seen, it does not support Folder Structure. If I'm wrong, I would love someone to tell me how to get it working.
XBMC did, quite successfully, catalogue my non-Folder-Structure movies. It lists them, with cover art, no problem. But, I have Avatar blu-ray and Troy blu-ray (don't ask; it was a 'gift') that I ripped to Folder Structure using AnyDVD-HD. Neither of them show up in the list of movies.
jmwills
Whadda you know.....a "Geek Classic" :lol:
ikon
You mean Troy? Puh-leeze! OK, not the worst movie ever, but far, far from the best.
Marshall_W
You should be able to identify the type of structure "folder" or "file" when you setup the library. This post may be helpful (http://forum.xbmc.org/showthread.php?tid=110279). Check the 6th post down...
Also... if you are new to XBMC, I strongly recommend you play around with the AEON SKIN. It is sharp, and light years better than the standard XBMC config.
ImTheTypeOfGuy
Can XBMC be run from a USB stick?
ikon, where is the download for the software?
Even though this has been off topic for a while, at least it keeps the post to the top. I am interested in the HTPC even though I don't need it.
Drashna Jaelre
Yes, indeed, it can be run from a disk. Get the XBMCBuntu distro. and whatever util it is, that allows you to apply the image to a USB drive. Or of you don't mind non-persistant settings, you *could* set up Windows Deployment Services, WDSLinux, NFS, and "live boot" off the network... Just saying. :P
And no, XBMC doesn't support playing live TV directly. You need a "backend" like MythTV, SageTV, MediaPortal or the like to do that. But you grab the appropriate plug-in for XBMC (and the "PVR" build of XBMC, or v12 beta/RC) and it connects to the backend. It supplies a Guide and the like, IIRC.
