WS2012E Connector / Possible DNS issue
Greg Welch
To make a long story short. lol
Installed my Windows 8 Pro client to server using connector within LAN. no problems
also tried to connect to server using connector from https ://xxxxx.remoteaccess.com/connect
will work, of course told me need to remove current connector.
Installed Direct Connect / Remote Access, along with VPN support. and completed Anywhere Access using windows domain https: //xxxxx.remotewebaccess.com no problems
tried installing my wife's Windows 8 Pro client using connector in LAN, after choosing download software on connector page I get popup "cannot locate or identify your server" tried Domain name and IP of server,
no luck
tried installing using https: //xxxxx.remoteaccess.com/connect
Will find server and gives me the following popups
"getting started"
".NET REQ 4.5 "
"Network Username and Password" (Her username is already on server as User)
"connect to xxxxx.remotewebaccess" popup asking for user, pass and domain
after entering the credentials says server is not available
any ideas guys, gals
  • Replies 31
  • diehard
    3
  • Greg Welch
    10
  • jmwills
    8
    8
Were these clients ever connected to the domain at any time previously? What is the DNS server? The router or the 2012 server?
yes, but were removed , DNS server is router
haven't touched .NET
thinking possible cert issue?
Having to retrace my steps after installing Direct Access
Not sure, but it seems that reinstalling .NET has fixed a lot of issues in the past, so wondering if it might help here too.
ya but I get the same "cant find server " from 2 machines, so im thinking its a server side issue
Also I can ping it, see it in the network folder, (no shares other that folder redirection)
Yeah. If the install won't work using the IP, there's an issue alright. Is it possible for you to stand up another server, even temporarily, maybe in a VM, and see if you can join the 2 clients to it?
Yes that I can confirm works, its only after adding Direct Access that I loose the connector ability
http://channel9.msdn.com/posts/Direct-Access-in-Windows-Server-2012-demo-and-interview
Reset the computer objects in AD. Right Click and select reset.
Remove the clients from the Domain (add to workgroup) and then rejoin to the domain.
