2 Bay Hard Drive Toaster that Will Clone for $19.99!
joem
That's a great price. I've used a different brand of duplicator dock. It worked OK, but it was quite slow. Despite it's slowness, it has the big advantage of being completely standalone: put the drives in, power up, press the right buttons, and voila, away it goes.
For RAID 0 and RAID 1 it says "You will also need to verify that each disk you intend to use in this array is the exact same make and model." I don't know if the device fails if that is not true or refuses to RAID or what. The rating comments has one mention of successful RAID use and one mention of unsuccessful RAID use, even with "identical" drives.
If you are trying to duplicate drives from RAID arrays, I can see where that might be a requirement. For non-RAID drives I would hope you can use 'similar' drives: i.e. duplicating to a drive that's at least as big as the original.
