Network device driver not found?
MAD4TECH
Hi can you help?
I am new to WHS i have an old gigabyte motherboard witch I thought of making it in to a windows home server i brought a oem copy of WHS 2011. The install seamed to go ok apart form a problem with the LAN Drivers was not found?? I have tried the latest drivers from gigabyte's web site and the ones for windows server 2003. But no luck the fault it shows is (network device driver not found)
The motherboard is a gigabyte GA-H55M-UD2H
i3 chip
8GB Ram
650GB boot drive
Windows home server 2011
I am new to servers so would appreciate any help you can give me thank.
Have you tried the Windows 7 x64 drivers?
thank you for the help it worked fine thanks agane :)
If the mobo is an H55 it can't be all that old, so I'm still thinking the Win7 driver should work. Seems it would be worth a try anyway.
Yes, I missed the H55 note. That board will work with WHS 2011 (see my Signature line)
  • 11 months later...
Hey All.....
Upgrading to 2011 from 2008 and was having a few issues that I was able to resolve from this forum. I have this exact
MOBO with he same issue. Also picked up a 120 gig ssd not knowing the 160 min. of which I also found here.
Thanks!
