cskenney
$289.99 HP ProLiant N40L Microserver Newegg Shell Shocker
jsox
These things only have a 150W power supply. That's enough for 4x 3.5" SATA drives?
Joe_Miner
Hey jsox! How's it going? Great meeting you at the Meet-Up in Indy!! I've read of people who are running 6x3.5" SATA drives. I've run up to 5 plus a SSD.
In my 2011 build I'm running 5*ST3000DM001's and a Corsair SSD plus a USB 3.0 PCIe card and 8GB of RAM. No problems.
Steady state power requirements are below 100W for 5 spindle drives plus an SSD though they do peak just over 110W at start-up. Check Power Requirements near the end of http://homeservershow.com/hp-microserver-n40l-build-and-bios-modification.html
Edited by Joe_Miner
ikon
Joe_Miner has it exactly right; it's the peak start-up power draw that matters. BTW, almost all PSUs have 'head room', meaning they can, for a short period of time, handle loads greater than their rated capacity. This can often be useful for handling startup loads.
Some people will say you should never rely on the head room, and for cheaper power supplies I must say I would agree. However, I have talked over the years with electronic engineers who actually design this stuff and have been told numerous times that it's quite safe; that their designs allow for at least a 20% overdraw. That means a 150W PSU can handle at least 180W for a short period.
So, if you want to add an extra drive or 2 to your system, and you find that the total power draw adds up to a few watts more than the PSU is rated for, I personally wouldn't worry about it. The ongoing, non-startup, power draw is bound to be well within the PSU's rating.
jsox
Darn! Went to pull the trigger and it was too late. Maybe next time.
cskenney
If you use the forums feature that allows you to follow the DEALS forum you can set your preferences to send you an immediate email any time anyone posts a new topic in our DEALS forum. That is one way to see posted deals before they expire and help increase your chance of snagging one of these Microservers when they are on sale.
    • Gulftown
      By Gulftown
      As I have decided to make some improvements on my afermarket fan controller I am trying to try implementing thermal control or mobo PWM control of additional fans, but before that I'm in a great need to inderstand how much fan count the controller should be ready to support. As this forum doesn't support polls I have nothing to do but ask you to reply on this topic.
      What I would be thankful to know:
      1. How many fans have you installed in your Microserver.
      2. What fans do you use (size, 3/4-pin connector) and where are they located, also what are they cooling.
      3. What way do you power these fans?
      Thank you in advance for your feedback!
    • Sokoban
      By Sokoban
      Hi
      My HP Proliant Microserver Gen 8 won't install HP Tools when I have running HP Smart Update Manager.
      even when I have trying to install via Intelligent Provising, Windows Server 2019.
      Se image below 🙂 That's I missing.. ;-(
    • Karazzi
      By Karazzi
      Hi everyone.
      New to this forum.
      I have a gen8 microserver running at home, where I have installed an SSD in the ODD sata slot. On the SSD I have installed Ubuntu Server 18.04.
      I have then created a logical volume witht the raid controller and can then boot to the SSD. So far so good.
      My problem emerges when I reboot the system. The logical volume disapears and it gives the error: "boot logical drive is configured but is missing or offline".
      I then have to go into the utility and reconfigure the logical volume. Kind of annoying, when trying to run a headless setup.
    • Mark Belanger
      By Mark Belanger
      Greetings,
      I'm new to the HPMSG8 world and so far I'm loving it. I have a stock Xeon with 16G of aftermarket memory with iLO patched to 2.70. Next up is adding a RAID card, so I can put my boot SSD on the onboard RAID. I picked up a LSI SAS9211-8i on Amazon, but am struggling to flash it to IT mode on the MicroServer. Is this even possible? Unfortunately, the only other system I have with PCI slots is 32-bit.
      Any pointers would be greatly appreciated.
      -MB
    • npapanik
      By npapanik
      FYI, I have just installed Windows Server 2019 Standard (Desktop Experience) using the latest (WS2016) HP AMD chipset & VGA driver. Everything is recognised in Device Manager and stable.
