Motherboard for WHS
ash
Hello All
This is my first post here so - Hello :D
I am hoping you can help me i have been pondering for a long time as to what mobo bundle to get for my windows home server.
I plan on running;
4way CCTV DVR card (1x PCI slot)
RAID 5 via highpoint card (1xPCIe slot)
Video and music streaming and converting
Central file and media server for the LAN as well as access away from the home
Backups
I have found this mobo which i believe will be good enough, any thoughts?
http://www.novatech.co.uk/products/motherboardbundles/mbb-32204g.html
I am starting my RAID off with 2x western digital 2TB 6Gbps Caviar hard drives running in raid 5
And i plan on having the operating system and internal applications on a separate drive is this possible?
I don't have a budget but i am also looking to buy less expensive components
Many thanks in advance
Please ask if you have any questions
  • Replies 22
  • ImTheTypeOfGuy
    2
  • jmwills
    9
    6
  • ash
    4
OK, first off, welcome to the HomeServerShow forums.
Now, I hate to be the bearer of bad news, but it's impossible to have a RAID5 array with only 2 drives - the minimum is 3. To lower the cost a bit, you might want to consider the WD Red drives instead of the Caviar. The Reds are designed for RAID use.
Generally, I wouldn't recommend having a WHS be used as a DVR. I would leave that to an HTPC.
I'm not familiar with NovaTech. It's not even clear from the website whether NovaTech is the mobo maker, or just the retailer.
I'm not quite sure what you mean by 'internal applications' but I highly recommend having the OS on it's own drive, separate from the data drives.
Okay thank you
Novatech is the retailer, i am not sure of the manufacturer of that board.
From what the website informs you, would you think it will be compatible with WHS2011
I would go with a name brand mobo. My preference is Gigabyte, with Asus & Intel second. At this point, it seems to me that an IvyBridge mobo would be the best option. For transcoding, I would go with an i5 or i7.
Okay thank you
Any motherboard will work with WHS2011. I say email them and ask what the model of the board is, then go from there. But from the looks of the bundle yea you should be fine with run WHS2011 with it.
If i was to start off with RAID1 as Ikon suggested, could i later change to RAID 5 when i add more drives?
And i have decided i will be going with the I5 i have found a gigabyte board with I5 for around £200 on amazon
Edited by ash
